Old 12-19-2008, 01:43 PM   #1
09TRD
Drives: 09 Yaris hatch, 09 Z51 'Vette
Originally Posted by Russelt3hPirate View Post
so you're saying my 9.9lb wheels will bend if I hit something?.
Yep, that's what I'm saying.
Any "racing" wheel will bend on roads like those we have here in the Northeast.
I've seen several Enkeis fold like accordians up here.
09TRD is offline
Old 12-19-2008, 02:01 PM   #2
Russelt3hPirate
l33t3st Asshole
Russelt3hPirate's Avatar
Drives: MY07 Yaris Liftback
I don't have enkeis.
So my CCWs will bend on your roads? but they weigh 25lbs for a 17x10?
please help me understand your logic and where your basis of argument is coming from.
by adding more material increasing weight does not automatically make a wheel "stronger" then a lighter counterpart.
I've also seen higher weight wheels bend. Alot of times it's due to the tire pressure being overly low, or the sidewall height being too short for the type of road.
Wheels are designed to bend when an extreme situation happens, it's better for them to bend then break.
by your "weight" standards those 17" centerlines wouldn't put up to squat. So what makes you think their 15" version is worth anything? because the website said so? :lol:
I feel spoke design (less spacing between spokes), proper sidewall height, proper tire pressure, and as much as safe pothole avoidance is going to save your wheels more then adding 2lbs of metal somewhere.
Russelt3hPirate is offline
Old 12-19-2008, 02:04 PM   #3
09TRD
I'm telling you that any "RACING" wheel isn't designed for STREET use.
Period.
That's because the barrel sections and the spoke sections are much thinner than what would be considered appropriate for STREET use.
Race tracks are SMOOTH, so thinner walls (which means lighter weight) are OK there.
Those Centerlines are thick-walled, FORGED 6061-T6 wheels.
They are MUCH stronger than any thin walled, cast wheel.
6061-T6's mechanical properties (e.g. yield strength) blow away the properties of cast aluminums.
http://en.wikipedia.org/wiki/6061_aluminum
Compare those propertied to A356 aluminum, which is the most common aluminum used in cast wheels:
http://www.mse.mtu.edu/classes/my413...inum/a356.html
09TRD is offline
Old 12-19-2008, 02:07 PM   #4
Tamago
Tamago's Avatar
Drives: UZJ100
Period.
question...
what makes a wheel a "racing" wheel? are AMERICAN RACING wheels RACING wheels because their name has RACING in it?
Tamago is offline
Old 12-19-2008, 02:12 PM   #5
09TRD
question...
what makes a wheel a "racing" wheel?...
http://www.6speedonline.com/forums/w...treet-use.html
"A word on BBS Race wheels for street use
I see many inquiries and threads on these wheels, and I think it's fair to warn people that don't know that these wheels were not designed for street use and BBS does not recommend them to be used off of a track. The barrel sections are roll formed and they are considerably thinner on these wheels than they would be on one of their road wheels. It saves weight, but it makes the wheel much more likely to be damaged by potholes, etc."
Cast aluminum racing wheels are typically made from A356 aluminum and are very light. By definition they can't be strong, since the material properties of that aluminum are quite low and since real racing wheels use very thin walls (in the barrel and the spokes).
Here are the material properties of A356, which is the most commonly used aluminum in cast wheels. They are laughable compared to a good forging:
Centerline wheels are fabricated exclusively from 6061-T6, which is a forged, aircraft grade aluminum. They also use thick walls, since they are designed primarily for STREET use.
http://asm.matweb.com/search/Specifi...ssnum=MA6061T6
09TRD is offline
Old 12-19-2008, 02:22 PM   #6
Russelt3hPirate
l33t3st Asshole
we got it, you read somewhere that a racing wheel from BBS isn't for the street
there are plenty of Racing wheels that aren't designed for street use and are sold as exactly that "only for Racing". Not all wheels that are light were designed with that one goal in mind, many wheels you would consider "race" wheels were designed for dual duty purposes and can handle the rigors of street use assuming you're not a retard.
will you please answer our questions?
Old 12-19-2008, 02:29 PM   #7
09TRD
Manufacturers go to extremes to save weight and increase fuel economy.
Cast aluminum wheels are common in OEM applications.
Show me just ONE OEM cast wheel that weighs anything close to 10 pounds. (20 pounds is closer to realty for most 15" and 16" OEM aluminum wheels).
You can't - despite the fact that such a wheel would be "win win" for the manufactures since they'd be CHEAPER to build (less material) and would yield a slight gain in fuel economy (lower weight and reduced rotating intertia).
So why don't they do it?
Answer: Because such a wheel would produce a flood of warranty claims in the form of bent rims.
Thin wall, cast aluminum wheels will BEND on roads like we have here in the Northeast and I've personally seen dozens that have.
09TRD is offline
Old 12-19-2008, 02:20 PM   #8
Russelt3hPirate
l33t3st Asshole
Period.
I'm just trying to understand your logic, you keep repeating the same thing over and over without actually addressing anything.
Would you consider a wheel that meets JWL standards good enough for the street?
The wheels I have are 15x7 +35mm Forged, so am I good to go?
I'd like to see a list of companies you feel make quality street wheels, just to get an idea of what you consider a "street" wheel.
I'm also curious if you're lumping all BBS wheels in with the "BBS Racing" wheels. I've had BBS wheels on my other car for ages now and they have held up amazingly well.
also, not all race tracks are smooth, and track wheels generally face more strain then your average street wheel. You ever hit a berm at 45 mph? those aren't little rumble strips like you feel on your xbox. :lol:
it's funny, I hear the exact opposite logic from people daily. "these wheels wont see the track so I don't need something forged/strong/stay in one piece"
and now you're saying that a quality wheel that is lightweight and forged is going to bend used on the street?
can you define "racing" wheel for us.
Slightly damaged wheel aucorium Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 12-06-2008 07:06 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
Wheel Advice caveatipse Cosmetic Modifications (Exterior/Interior) 8 09-19-2007 02:39 AM
Yaris wheel rate ratio (06+) ? dsc_pat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 07-05-2007 05:43 PM
