Old 12-23-2008, 03:17 PM   #1
Originally Posted by andries View Post
You must jack up the car so the tension is off the shock bolts.( to pushing them back as the nut is off) Then fit the sway bar.
10 min. work (with two people 5 min.) and then you have a very great mod. Your car will be a lot better handling.
good luck
Jacking is not necessary. I put two on with the cars sitting naturally. Shock mount bolts slide easily even with the vehicle weight on them. If you a small enough to worm your way under the car without jacking or ramps, then you are good to go.
Old 12-25-2008, 06:04 PM   #2
bikegerm
bikegerm's Avatar
Drives: 2007 Meteor LB
align?
Will I need a rear end alignment after I loosen those bolts and attach the sway bar?
Merry Christmas !!
Randy LeRoy
www.airshowmastering.com
randy@airshowmastering.com
bikegerm is offline   Reply With Quote
Old 12-26-2008, 02:46 AM   #3
uncleyaris
Great job BTW!!!!
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-06-2008 12:37 AM
Difference b/w TRD Rear Sway Bar and these? IsLNdbOi Performance Modifications 8 11-11-2008 10:13 PM
DIY - TRD rear sway bar kurokoma-kun DIY / Maintenance / Service 0 10-20-2008 02:21 PM
Best place to purchase a Tanabe strut bar and or TRD Rear anti sway bar? thomasward00 General Yaris / Vitz Discussion 3 07-12-2007 02:22 AM
TRD rear sway bar chrisada_to2a Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 05-13-2007 05:43 PM
