Old 06-26-2014, 04:41 AM   #1
BADIS
Drives: Toyota Yaris 2007
Hi all. I'm planning to buy and mount a tachometer and water heat gauges on my Yaris 2007 Sedan. I've seen some loose wires and harnesses near the engin. These are unplugged . My yaris is number 2. It comes without RPM and Water heat Gauges. I bought it in Sultanate of Oman. My question is: does Yaris come with ready harnesses to plug and play my gauges? Otherwise, could you please show me how to mount them? What and where are the right wires located?
Thanks in advance
BADIS is offline   Reply With Quote
Old 11-01-2014, 12:28 AM   #2
"G"
Drives: 2007 Yaris Hatch
Where is the wire for the seat belt alarm?
"G" is offline   Reply With Quote
Old 11-01-2014, 07:52 AM   #3
The driver's side one is under the driver's seat and then it goes under the center console directly to the SRS ECU. The passenger one is under the passenger seat and it goes to the Occupant Classification ECU and then that ECU communicates with the SRS ECU to relay the info.
What exactly are you looking to do with that wire?
Old 11-01-2014, 07:54 PM   #4
wufai
Drives: Silver Yaris Sedan (4A)
So does that mean if I want to steal a yaris like they do it in the movies I need to cut the yellow, pink and black wires and tap the yellow leads against the pink and black?
wufai is offline   Reply With Quote
Old 11-18-2014, 09:10 PM   #5
gabbhie
Drives: yaris sedan
hi CTScott. where can i see the hotwire for parklights that is usually used in aftermarket alarms..when you press the lock/unlock button of alarm the parklight will blink once or twice.
gabbhie is offline   Reply With Quote
Old 11-18-2014, 09:13 PM   #6
Look at my remote start wiring guide for where you can grab the parking light feed. Just verify that the wire colors match, as the Yaris in your market may be wired a bit different.
http://www.yarisworld.com/forums/showthread.php?t=24860
Old 11-18-2014, 09:22 PM   #7
gabbhie
Drives: yaris sedan
oh i see, but i already tried that wire. its not the wire for the parklights.
i have owned my yaris since last year and until now theres no park light signal when i lock/unlock
Old 11-18-2014, 09:34 PM   #8
Post some pictures of the connector for your headlight switch.
Old 02-03-2015, 11:00 PM   #9
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
CTScott do you have a wiring diagram for the 3rd gen Yaris? In particular I'm interested in the body ECU and what wires go where.
Old 08-25-2015, 01:09 PM   #10
Kitt
Kitt's Avatar
Drives: Thndr cl metallic HB 3 drs '05
Send a message via MSN to Kitt
Im planning to add a gauge 2 cable for my amp on my new car from the battery, however, I'm not sure where is the right place to do so. Do I have to drill the firewall?
20 years... alive and kickin'!!
Kitt is offline   Reply With Quote
Old 08-25-2015, 07:45 PM   #11
There is no power feed inside the cabin that you can connect that large of a wire to. You can go through the large grommet that is behind the battery, rather than drilling the firewall.
Old 01-21-2016, 01:27 PM   #12
frankienap
Drives: Yaris 2008 Sedan
Desperately looking for the 12v + reverse wire on the rear tail light
Looking to add power to an aftermarket backup camera. I've searched for over 3 hours for the location of this wire. Here's a picture of the connection for the left rear light assembly on my 2008 Yaris Sedan. Anyone know which wire?
The wires going into the rear lights are: purple, green, orange, white w/a black strip and light blue.
Many many thanks!
frankienap is offline   Reply With Quote
Old 01-21-2016, 09:54 PM   #13
Many many thanks!
If you look at the 12 pin connector which connects to the taillight, the red in pin 5 on the right and brown in pin 5 on the left is reverse.
Old 01-21-2016, 02:25 PM   #14
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
If nobody answers, you could get a test light and turn the key to accesories. With the hand brake up, you could just put it in reverse. Use a test light and back probe each wire. Record which ones have power. Then put it back into park and check again to see which one no longer has voltage. I can't look up the wire diagram right now while i am at work. CTScott would be the one to get the info to you the fastest.
-Derrick-
Old 01-21-2016, 03:13 PM   #15
frankienap
I think I'm going to pick up a voltage detector from Lowes tonight. One more question: will I be able to tell which wire coming from the reverse light is positive (versus negative) simply using an analog voltage detector?
Old 09-17-2017, 08:04 PM   #16
Stabicraft
Drives: 2008 BLACK YARIS
can you please tell me where to take off a 12 volt feed (when the high beam is activated) for my driving lights relay.
Little or no voltage or current required, just power ONLY when high beam is activated.
Thanking you in advance.
Stabicraft is offline   Reply With Quote
Old 11-16-2017, 01:27 AM   #17
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
The headlights are earthed to turn on, with permanent 12v power. The simple way is to wire the relay coil across the 2 parallel contacts on the headlight socket.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Old 11-15-2017, 10:42 PM   #18
Mister-twister
Drives: 2009 Yaris hatchback
People who can share wire schematic/diagram for master windows switch. Look to hookup original master switch to aftermarket power window kit want use original switch instead of one from kit to have auto option.
Mister-twister is offline   Reply With Quote
2012 Yaris at SEMA Jason@SportsCar Third Gen Yaris General Discussion 5 09-23-2013 03:55 AM
New Yaris race car Jason@SportsCar Tracking, Racing, Auto-X Forum 83 11-01-2012 02:32 PM
