Nov 2006
Drives: Vitz S1600 Join Date: Apr 2007
#2 | |
![]() ![]() ![]() Drives: 08 sedan at Join Date: Dec 2008
otherwise you should get professional work |
![]() ![]() ![]() ![]() Drives: '08 Yaris sedan , '08 Liftback Join Date: Oct 2008
did you try draining the oil and then pour in a cheap oil to reflush ? Hope you have better luck .
I've seen so much tarnish on these ( sign of no or very few oil changes ) and wrong sized dipsticks in quite a few used older SCION XBs ( cousin of YARIS ) that are /were for sale at small and large dealerships , including TOYOTA
. Should have metal like in the YARIS sedan .
#5 | |
I'd say don't wait due to the consequences . Better to be safe than sorry . Few hundred dollars lost better than thousands .
use WAL-MARTS cheap regular or synthetic . Some people swear by it .
dropping the pan be best , that's if you have the knowledge and nerve . Changing the oil filter several times and look inside to see if any particles . May want to pour oil from one pan / bucket to another using screen ( metal , nylon that used for window and doors ) and cover it so can capture any pieces for examination .
may find it in oil filter sooner or later
I do hope for the best of luck to you . You could take it to trust worthy garage / mechanic for advice or even have them remove pan . Shouldn't be all that much if you supply the oil , filter , and gasket . Just pay for the labor and would be under warranty . Probably be less than $125 for parts and labor . Better than engine possibly taking a crap .
Drives: 2007 Black Yaris Join Date: Aug 2007
Careful. I talked about changing to a metal dipstick and got harrassed and beaten to a pulp, and banned. You doit, and you are a hero. Do you not all see the hypocrisy??
#14 | |
You are a broken dipstick
![]() "Manual labour is not for me. In fact i'm not even sure non manual work is either." -Anthony Linton Check out ▬▬► I like I like ◄▬▬ for more fun on Facebook |
![]() ![]() ![]() Drives: 2010 Mazda3 iTouring Join Date: Jun 2007
HAHAHA Caveatipse was right
![]() ![]() ![]() ![]() Drives: Yaris Sedan 5MT Join Date: Oct 2008
Really?? you must post Negative warnings in all the posts? See, what you are currently doing is called Trolling.... Baiting people to respond to you, such as what you got me to do here.
It's been brought up by another member, all you had to do was shut up. No need to respond, my last comment about such topic.
Learn to Relax
You could probably fish it out or flush it out through the drain plug. It's plastic so it would flush out. The sooner you do it the better. If it breaks up into little pieces, it could block oil from flowing through your engine. That would be the end of your engine.
![]() ![]() ![]() Drives: Blazing Blue Liftback Join Date: Oct 2008
Mine has a metal dipstick, and it's a liftback.
| DIY: CHANGE MANUAL TRANNY OIL | ttufrosty | DIY / Maintenance / Service | 157 | 09-07-2018 01:43 PM |
| Engine oil ddi not come out | hans_fh | DIY / Maintenance / Service | 18 | 01-23-2009 11:30 PM |
| oil and oil filter question.. | marcus | DIY / Maintenance / Service | 27 | 07-11-2007 03:25 PM |
| metal particles in oil | 007 hatch | DIY / Maintenance / Service | 9 | 06-22-2007 02:56 AM |
