Joey
Drives: '14 Scion xD 5-speed Join Date: Oct 2008
As your oil darkens and ages, it'll eventually start to burn. If you check the oil and it's jet black, then you can bet you've burned way too much so it'll drain less than the full 4-quarts on the change. That means you gotta change your oil right away, otherwise your pistons will seize-up and you'll be out shopping for a new engine real soon.
Formerly owned Met-Met. '07 Yaris LB 5-speed. A forum post should be like a skirt: Long enough to cover the subject but short enough to keep things interesting. "I don't have an anger problem. I have an idiot problem." -Hank Hill |
| DIY: CHANGE MANUAL TRANNY OIL | ttufrosty | DIY / Maintenance / Service | 157 | 09-07-2018 01:43 PM |
| Engine oil ddi not come out | hans_fh | DIY / Maintenance / Service | 18 | 01-23-2009 11:30 PM |
| Nippon Oil Filter | IllusionX | DIY / Maintenance / Service | 6 | 12-07-2008 02:00 AM |
| oil and oil filter question.. | marcus | DIY / Maintenance / Service | 27 | 07-11-2007 03:25 PM |
