Old 01-02-2009, 02:29 PM   #1
Tamago
Tamago's Avatar
Drives: UZJ100
the fram PH4386 is recommended for the "high performance" toyota engines of the 80's... it's about 1" longer than the PH4967 (which is the same overall size as the OE toyota filter)
i personally run the "truck" filter from toyota, it's much larger diameter, and much longer.. i have no valve tapping issues
Old 01-02-2009, 10:02 PM   #2
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
please enlighten us some more on this "TRUCK" filter.....
Old 01-03-2009, 02:20 AM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
90915-YZZD3 is the filter used on toyota's larger engines... used to be called a "truck" filter because toyota didn't have any big "car" engines.. so it's sometimes referred to as a "truck" filter..
the big one...
but you should know this since you WORK for toyota....
Old 01-05-2009, 08:07 PM   #4
ROCKLAND TOYOTA
TRIM HUNTER
the big one...
i understood what you meant i just find it funny that your using a v8 filter with no problems......
Old 01-05-2009, 08:09 PM   #5
Tamago
Tamago's Avatar
Drives: UZJ100
yeah, sure looks like you knew what i was talking about
what "problems" would i run into running an oversized filter?
Old 01-05-2009, 08:13 PM   #6
ROCKLAND TOYOTA
TRIM HUNTER
OH, i see for 2009 were still gonna be a asspaper, HUH. no problem, good luck with the thread...... unsubscribed
Old 01-05-2009, 09:02 PM   #7
Tamago
Tamago's Avatar
Drives: UZJ100
it's a serious question, what problems do you expect me to be having with a larger filter?
Nippon Oil Filter IllusionX DIY / Maintenance / Service 6 12-07-2008 02:00 AM
What about the oil filter???? Driver DIY / Maintenance / Service 28 10-23-2008 11:45 PM
oil and oil filter question.. marcus DIY / Maintenance / Service 27 07-11-2007 03:25 PM
don't think the dealer changed oil filter on first change gonzo452001 DIY / Maintenance / Service 0 01-13-2007 11:44 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
