Old 01-02-2009, 10:02 PM   #1
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
i personally run the "truck" filter from toyota, it's much larger diameter, and much longer.. i have no valve tapping issues
please enlighten us some more on this "TRUCK" filter.....
Old 01-03-2009, 02:20 AM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
90915-YZZD3 is the filter used on toyota's larger engines... used to be called a "truck" filter because toyota didn't have any big "car" engines.. so it's sometimes referred to as a "truck" filter..
the big one...
but you should know this since you WORK for toyota....
Old 01-05-2009, 08:07 PM   #3
ROCKLAND TOYOTA
TRIM HUNTER
the big one...
i understood what you meant i just find it funny that your using a v8 filter with no problems......
Old 01-05-2009, 08:09 PM   #4
Tamago
Tamago's Avatar
Drives: UZJ100
yeah, sure looks like you knew what i was talking about
what "problems" would i run into running an oversized filter?
Old 01-05-2009, 08:13 PM   #5
ROCKLAND TOYOTA
TRIM HUNTER
OH, i see for 2009 were still gonna be a asspaper, HUH. no problem, good luck with the thread...... unsubscribed
Old 01-05-2009, 09:02 PM   #6
Tamago
Tamago's Avatar
Drives: UZJ100
it's a serious question, what problems do you expect me to be having with a larger filter?
Old 01-06-2009, 10:45 AM   #7
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
You probably wont have any problems running a larger filter but if it costs more than the regular filter you are wasting your money.
Nippon Oil Filter IllusionX DIY / Maintenance / Service 6 12-07-2008 02:00 AM
What about the oil filter???? Driver DIY / Maintenance / Service 28 10-23-2008 11:45 PM
oil and oil filter question.. marcus DIY / Maintenance / Service 27 07-11-2007 03:25 PM
don't think the dealer changed oil filter on first change gonzo452001 DIY / Maintenance / Service 0 01-13-2007 11:44 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
