Old 08-15-2007, 12:51 AM   #19
ttufrosty
I too am looking to go to AMsoil 75W-90, I did find these two topics on the Scions. At least they are a starting point on what to do if you need a visual reference.
Changing an Xb
http://s49.photobucket.com/albums/f2...0Oil%20Change/
Changing a tC
http://www.scionlife.com/forums/viewtopic.php?t=120673
ttufrosty is offline   Reply With Quote
Old 08-15-2007, 12:59 AM   #20
Black Yaris
der Zeck
Black Yaris's Avatar
Originally Posted by nsmitchell View Post
It must be the new manual trannys, but in all the manuals I've ever done, I just used a normal motor oil like Mobil-1 10W-30. They all shifted like a dream! 75W-90 is some thick stuff. I wonder why it needs to be so thick?
Don't know what kind of manuals you drove but every manual I know of either takes gear lube (75w-90, 75w-140, etc), or many mazda/ford manual trannys actually take ATF.
Changing an Xb
Changing a tC
I just changed mine to Amsoil as well, after I got my car up on ramps and saw the large fill and drain plugs plainly labled "see owners manual before refilling"... it was a simple job with the beer bong funnel to fill her up...
Old 08-15-2007, 01:39 AM   #21
ttufrosty
Here is another topic from Scionlife with lots of info on changing the manual tranny fluid as well as info on particular gear oil to use.
http://www.scionlife.com/forums/view...n+oil&&start=0
Old 08-15-2007, 07:44 PM   #22
hystria
hystria's Avatar
Drives: 2007 Orange Yaris Hb 3Drs
Syncromesh Friction Modified sell by GM for manual Corvette transmissions will help having smoother gear shifting after a while
hystria is offline   Reply With Quote
Old 08-23-2007, 08:38 PM   #23
JosephDoc
Drives: 07 Yaris 3D
Originally Posted by blacksan View Post
Manual Transmission,.....GL-5
All TEMPS......75W-90
Severe Gear 75W-90
SAE 75W-90 Synthetic Gear Lube
-------------------------- Thanks for the backing up. I thought I've used the wrong oil.
I just did my first oil change @ 2k miles. I replaced both motor and transaxle (manual transmission) fluids @ 2k miles since my wife is a stick-shift noob and I feel secured to get it done early.
I use "Eneos-0w20" for motor oil, and "AMS SEVERE GEAR Synth 75-90" for the tranny. Why? Don't ask but let me finish... I know Eneos' quality and I am a JDM fan, but since Eneos has not released their 75w90 in USA so I pick the best by AMS.
But why sever-duty grade in a little Yaris? I was not so sure but it was recommended by a good friend who works in the parts store. So the truth is on all newer Toyotas, the manual tranny does require GL4 or GL5 fluids as it says in Techinfo-Toyota. I could not find out more support material about AMS's "SEVERE GEAR Synth 75-90" but I guess I have to trust good friends' advise when I am not a pro at it. With or without the servere-grade label, I pick the servere grade since I notice frequently I push the car a bit harder than my other cars since the Yaris has a small engine.
Now the car runs much smoother and overall vibration has clammed down a lot. It works!! I am also expecting to see some gaining in MGP in next few weeks.
JosephDoc is offline   Reply With Quote
Old 08-24-2007, 12:50 AM   #24
Black Yaris
der Zeck
Joseph.... I have found that if you are pushing the car every now and again. 0w20 is no good.... the 20 weight is a little too thin... need to go to 0w30 if you are harder on your car, that is what I am now running, I had to change the 0w20 early because it was so dark, yes it was full synth.... after doing a little more reading online 0w30 is the way to go, it is actually the #1 recommended replacment oil for cars that came with 5w30 from the factory
Old 08-24-2007, 10:25 PM   #25
WolfWings
WolfWings's Avatar
3rd-gen Civic manual transmissions specified 30W engine-oil for the transmission, actually. Not 10W-30, 30W. And not gear oil, motor oil. Single-grade motor oil, in a transmission. Still want one of those again.
They also happened to specify that for the engine itself as an option in climates that didn't get below 20F/-7C, so on my '86 Civic I had straight 30W oil in the entire vehicle.
Old 01-06-2009, 06:05 PM   #26
1stToyota
1stToyota's Avatar
Originally Posted by xpeteyjtx View Post
It should be in your manual, homie. You can also find a .pdf copy of the owners manual at http://www.etimago.com/yaris/repairmanual/
Manual Transaxle
Oil type: API GL-4 or GL-5
75W-90
2 quarts or 1.9 Liters
If you look at the technical data on GL-4 and GL-5 it's easy to see that GL-4 is specifically designed for transmissions with their soft metals, and GL-5 is designed for differentials. Most synthetic 75W-90 is GL-5. I've only been able to find two 75W-90s that are available in GL-4; AMSOIL and Pennzoil. It's harder to find but I'd much rather have the gear oil that's designed for a manual transaxle.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 01-06-2009, 06:41 PM   #27
jkuchta
Drives: 2007 Yaris hatch (red)
The redline is a GL-4, and is designed specifically for Toyota synchros.
jkuchta is offline   Reply With Quote
Old 01-06-2009, 07:24 PM   #28
1stToyota
1stToyota's Avatar
Is it really?
On their site I'm seeing 75w-90 and 75w-90 NS, both listed as GL-5. I really didn't study what they claimed about the 75w-90, but the 75w-90 NS shows to work in transmissions, as well as differentials. If they had a 3rd choice of a GL-4 75w-90 I guess I didn't find it.
2008 Scion xD
Old 01-06-2009, 07:31 PM   #29
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
the royal purple 75w90 oil we use in our differentials at work in semi trucks is the same stuff i used in my yaris. its max life 75w90 which i believe is what other royal purple useres used.
Old 01-06-2009, 07:34 PM   #30
jkuchta
1stToyota, the redline product you want is called MT-90.
Old 01-06-2009, 08:14 PM   #31
gid
+1
is GL-4 . Says it on the bottle as well . Otherwise I wouldn't use it .
Old 01-07-2009, 09:38 AM   #32
1stToyota
1stToyota's Avatar
Thanks. We're gettin' things done now. That's three synthetic 75W-90s that we know for sure are GL-4 rated: Redline MT-90, AMSOIL's transmission/transaxle fluid, Pennzoil's GL-4 75W-90
2008 Scion xD
Old 01-07-2009, 11:56 AM   #33
Chupacabra
Drives: 2009 Yaris liftback
After putting the MT-90 in nearly all my cars...I highly recommend it in the Yaris. The shifts are like butter now (especially reverse).
Chupacabra is offline   Reply With Quote
Old 01-07-2009, 12:32 PM   #34
gid
don't mean to be nosey ...
what other vehicles you have ?
Old 01-07-2009, 12:49 PM   #35
Chupacabra
1963 split Window Corvette Fuelie (MINT)
1973 Camaro Type LT with 383 stroker (MINT)
1988 BMW M3-Evo 3 spec (MINT)
1988 BMW 535is
and a few others for now... I am waiting for the market to turn around a bit before I get excited over anything else. I will be building a 6 car garage and adding onto my house in the next few years so...a lot of money will be funneled in that direction.
Old 01-08-2009, 01:37 AM   #36
gid
you could be the next JAY LENO . Nice collection too .
Manual Yaris performance info? SimmZ General Yaris / Vitz Discussion 22 10-27-2009 10:27 AM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 05:25 PM
The Toyota Authorized Repair Manual. LoudYar General Yaris / Vitz Discussion 3 03-29-2007 01:20 AM
2007 LB Yaris - AT - Fluid Change Interval Pavel Olavich DIY / Maintenance / Service 9 03-21-2007 07:09 PM
Maintenance - Change Auto Trans Fluid Linkseal DIY / Maintenance / Service 1 08-15-2006 11:57 PM
