You could remove the sensorand bracket , and twist the metal leg on it 90 deg, then losen the top 3" hose clip side it under and do hose clip up again.
The Spare bolt (M6X30mm and 2 washers are used if you did not remove the orginal airbox mounting bracket, theres a hole in the bottom of the AFE box that lines up with the bracket . That's if you did not remove it ,when you removed original airbox . Last edited by 1NZYaris1; 01-08-2009 at 02:01 AM. |
#2 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Bayou Blue LB AT Join Date: Oct 2008
aFe Intake | Blitz Supercharger | Megan Header | TRD Exhaust | NST Pulley Set TRD Shocks/Struts | Tanabe NF210 Springs | TRD Sway Bar | Motegi TRAKLITE wheels | Kuhmo Ecsta XS R1 Concepts slotted rotors | Carbotech 1521 brake pads | stainless steel brake lines | Seibon vented carbon fiber hood |
looking good, but i am so happy i bought the k&n short ram when it was $230 for some reason it is around $330 now, they must be crazy.
Thats why the AFE system is so good and popular it's half that price.
def the reason hopefully k&n want sell to many and the price will drop.
Hey, did you just screw that sensor bracket to the radiator filler cap tube base or did K&N supply a special part?
AFE INTAKE
Can I put the 07-08 AFE Intake on an 09 HB?
Yes you can, go for it , Talk to Garm (cali Yaris)
and enjoy it . |
| Afe intake feed back required. | 1NZYaris1 | Performance Modifications | 51 | 03-20-2009 07:25 PM |
| (for Doc Zaius) aFe intake on a Blitz'd engine | LtNoogie | Performance Modifications | 23 | 12-15-2008 01:25 PM |
| AFE Intake on a Sedan??? | CASTREX | Performance Modifications | 7 | 12-12-2008 12:27 PM |
| Amp install under the passenger seat questions.. | MudBug | In Car Entertainment + Electronics (audio / video / alarm) | 19 | 06-06-2007 11:12 AM |
