Old 01-09-2009, 05:21 PM   #1
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
You could remove the sensorand bracket , and twist the metal leg on it 90 deg, then losen the top 3" hose clip side it under and do hose clip up again.
The Spare bolt (M6X30mm and 2 washers are used if you did not remove the orginal airbox mounting bracket, theres a hole in the bottom of the AFE box that lines up with the bracket .
That's if you did not remove it ,when you removed original airbox .
The Toyota dealer must have removed that bracket when they originally installed my TRD CAI. I was wondering why I had so much loose hardware leftover.
Old 01-09-2009, 06:08 PM   #2
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Loose hardware for a loose unit
Old 01-09-2009, 06:17 PM   #3
kou
Drives: 08 lb
looking good, but i am so happy i bought the k&n short ram when it was $230 for some reason it is around $330 now, they must be crazy.
Old 01-09-2009, 06:33 PM   #4
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Thats why the AFE system is so good and popular it's half that price.
Old 01-09-2009, 06:35 PM   #5
kou
Drives: 08 lb
def the reason hopefully k&n want sell to many and the price will drop.
Old 01-09-2009, 07:12 PM   #6
auxmike
auxmike's Avatar
Hey, did you just screw that sensor bracket to the radiator filler cap tube base or did K&N supply a special part?
Old 01-12-2009, 01:36 PM   #7
nvidiaxtc
nvidiaxtc's Avatar
Drives: Black 2009 3Dr Hatch
AFE INTAKE
Can I put the 07-08 AFE Intake on an 09 HB?
nvidiaxtc is offline   Reply With Quote
Old 01-12-2009, 03:19 PM   #8
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Yes you can, go for it , Talk to Garm (cali Yaris)
and enjoy it .
Afe intake feed back required. 1NZYaris1 Performance Modifications 51 03-20-2009 07:25 PM
(for Doc Zaius) aFe intake on a Blitz'd engine LtNoogie Performance Modifications 23 12-15-2008 01:25 PM
AFE Intake on a Sedan??? CASTREX Performance Modifications 7 12-12-2008 12:27 PM
Amp install under the passenger seat questions.. MudBug In Car Entertainment + Electronics (audio / video / alarm) 19 06-06-2007 11:12 AM
