Old 01-21-2009, 11:34 PM   #1
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Originally Posted by REM View Post
Thanks guys. I just canceled my order for the 18s. I think I found some that I'm going to go with: 17x7 with an offset of 45. Those should work if I go with 205 tires , right?
Much much MUCH better.
Old 01-22-2009, 08:22 AM   #2
REM
REM's Avatar
Drives: 2012 Nissan Leaf SL
Good because I won the auction.
Cheers,
Ryan
REM is offline   Reply With Quote
Old 01-22-2009, 12:01 PM   #3
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Yeah.. that's as good as you can get with a 17" wheel on the Yaris.
Your tires of choice should be 205/40/17
Old 01-22-2009, 12:27 PM   #4
REM
REM's Avatar
Not 205/45/17?
Cheers,
Ryan
Old 01-22-2009, 01:32 PM   #5
CASTREX
CASTREX's Avatar
Not 205/45/17?
You can probably fit 205/45 with no problem. And the car will probably be more confortable.
My car is a Yaris TS and came from factory with 205/45/17 wheels.
Altough the best match to the US OEM wheel sizes would be 205/40.
Also, there are more tire options on 205/40 than in 205/45.
Are you lowered or planning to drop your car?
If you are going for a close to 2" drop stay with the 205/40's If you are dropping around 1" then 205/45
That will minimize any rubbing on the plastic inner fender over speed bumps.
Old 01-22-2009, 05:12 PM   #6
REM
REM's Avatar
My driveway inhibits any idea of lowering my car right now. Maybe in a few years when I buy another house, but until then I will keep my Yaris stock in that department.
I should probably just go with the 205/40s because they will leave me more leeway in the future, though. Thanks again for all the advice!
Cheers,
Ryan
Old 01-22-2009, 05:30 PM   #7
REM
REM's Avatar
Let me just thank you again for suggesting 205/40s. I just purchased a set and saved $125 on the same exact tires, only 205/40s instead of 205/45s. I had no idea the price difference!
Cheers,
Ryan
Old 01-22-2009, 07:01 PM   #8
CASTREX
CASTREX's Avatar
Yeap that's right. The 205/45 is not that common of a tire. From the top of my head I can only think on the Mini Cooper which comes with 205/45 from factory.
On the other side the 205/40/17 is a really common tire size on the Honda tuning world... hence why more common and cheap.
05 AU Yaris Stock Speakers + Alpine iDA-X001 thatfilthyspringbok In Car Entertainment + Electronics (audio / video / alarm) 2 09-10-2007 08:06 AM
Yaris Body Kit Available in US - SEMA Yaris DJFMedia Cosmetic Modifications (Exterior/Interior) 26 10-21-2006 02:00 PM
