OMGWTFKITTYKATMEWMEWMEW
Drives: 2008 Yaris S Join Date: Oct 2008
Oil change time intervals
Back when I was first learning about cars, my dad told me to change the oil every 3k miles or 3 months (average drivers hit about 1k miles a month).
I pretty much only drive my car on the weekends because I have a work vehicle that I use during most of the week. So here's my question... Should I be changing the oil every few months even if I'm not hitting the set mileage? I don't want this to be some debate about the length of the intervals (3 months vs. 5 months, etc.) just curious if it's a good idea to change the oil on set time intervals.
#2 | |
Drives: 2009 Yaris liftback Join Date: Nov 2008
For normal driving with the Yaris, 5000 miles or 6 months (which ever comes first) is fine...
kk sounds good. thx for the replies.
Depends on where you are getting your oil changes done. If your getting it a lube shop then your getting recycled oil so yes you must change it every 3k miles. If you are getting it done at the dealer or using ur own oil than probally every 5k. If you drive in heavy traffic long commutes every day then yes you should change it every 3k. If you do mostly freeway driving then every 5k.
The 3k 5k is mainly jsut a rule of thumb. Do you know how jet planes determine thier oil change intervails? Not based on how many miles the plane flys. But by how many hours the engine is on. Which is really the true way to base it. If you take in to account all the time you are stuck in traffic stuck in stop lights you are putting wear on the engine and oil. Which is why you should change it more often in harse conditions. If you want to extend your drain intervails the safest most effective way is switch to a synthetic oil. Will withstand harsher conditions such as stop and guy and consistant high rpms. Oil change is the simplest and most inexpensive maintanance you can do for your vehicle but has the largest impact if you neglect to do it. Oil change is cheap why not do it often. Although i dont recommend bouncing from place to place whoever has the cheapest oil change as it is best to take your car to one shop you know and trust consistantly cause they will know your car best and its maintanace records. If price and budget is a concern there are many compedators that advertise low oil changes to get you in the door. some as low as 12.99. At that price you cant afford not to change you oil frequently. Just be weary as they will try to upsell you unneeded items or items before they are really needed such as air filters, brakes, fluid services and fuel injection/air induction services. |
YarisSedan,
Before you start spewing your bullshit all over the internet, you should know the facts dude. I happen to manage a lube shop. Where the hell you get off saying that lube shops use recycled oil is beyond me. Pull your head out and know what you are talking about. We sale the same brands that you find on the shelf at Wal-Mart or auto parts stores. Because they have oil in bulk tanks doesn't mean it is recycled. There are enough misconceptions about our industry without knuckleheads like you spreading your crap. As far those unneeded items you refer to, why don't you do your homework. Go look at AAA's website or google Car Care Aware. How long do you think an air filter is supposed to last? Get a life and quit passing out your ignorant advice.
'07 Polar White Liftback, 15in Alloy Wheels, Exhaust Tip, Cruise Control, Tinted Windows, TRD Valve Caps, PadsPlus Pads, |
I like how this thread went off-topic within 5 posts and turned into exactly what I stated in my original post I didn't want this thread to turn into.
#8 | |
What the Pho?
Drives: '08 Meteorite Metallic MT LB Join Date: Oct 2008
I hear quick lube gets their oil from the recycle tanks at Wal-mart. Why do think they offer to take it for free, because they turn around and resell it... Of course I'm
'ing you... Recycled Oil... ![]() At least the hour meter for engine oil change intervals was accurate... |
#11 | |
And did you even read my first post? None of this acknowledges anything I was asking. You should have made your own thread if you felt like jacking mine.
Double threads on this subject... Well there are a lot more but two current ones anyway...-
http://www.yarisworld.com/forums/showthread.php?t=13184 |
Bacon!
Drives: 2008 Red Yaris LB Join Date: Oct 2008
#14 | |
Also, check the time stamp on that thread you linked. I posted mine hours before that one.
#15 | |
#16 | |
#17 |
Drives: 2007 Yaris Hatchback Join Date: Oct 2008
I just moved out into the country, and my drive to work is about 95% 80mph each way, for a total of 140 miles round trip. So I'm really easy on the oil. I use only synthetic 0w-20 and my wear numbers are actually lower then most Yarii that use a higher viscosity. Given my drive, I plan on changing the oil every 7,000 miles. I currently got 51,000 miles on the odometer, and should be around 90,000 miles by this time next year. Yaris are great cars!
#18 | |
| DIY: CHANGE MANUAL TRANNY OIL | ttufrosty | DIY / Maintenance / Service | 157 | 09-07-2018 01:43 PM |
| Get your post counts here! *read 1st post for rules* | Astroman | Off-topic / Other Cars / Everything else Discussions | 3414 | 11-04-2012 09:03 AM |
| Help with oil change specs | autophile | DIY / Maintenance / Service | 31 | 04-25-2011 09:22 PM |
| Oil change time... yay! | YarisFan007 | DIY / Maintenance / Service | 10 | 09-19-2007 05:40 AM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 08:16 PM |
