Old 01-27-2009, 08:06 PM   #1
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Double threads on this subject... Well there are a lot more but two current ones anyway...-
http://www.yarisworld.com/forums/showthread.php?t=13184
Old 01-27-2009, 09:25 PM   #2
PaidTimeOff
OMGWTFKITTYKATMEWMEWMEW
Drives: 2008 Yaris S
That thread you linked is about mileage, not about the amount of time between oil changes. I did a search before I posted this thread and only came up with mileage debate threads. Reread my first post.
Also, check the time stamp on that thread you linked. I posted mine hours before that one.
PaidTimeOff is offline   Reply With Quote
Old 01-27-2009, 10:18 PM   #3
PetersRedYaris
Yeah, I know you were first...
Old 01-29-2009, 04:52 PM   #4
SilverGlow
Drives: 2007 Yaris Hatchback
I just moved out into the country, and my drive to work is about 95% 80mph each way, for a total of 140 miles round trip. So I'm really easy on the oil. I use only synthetic 0w-20 and my wear numbers are actually lower then most Yarii that use a higher viscosity. Given my drive, I plan on changing the oil every 7,000 miles. I currently got 51,000 miles on the odometer, and should be around 90,000 miles by this time next year. Yaris are great cars!
SilverGlow is offline   Reply With Quote
Old 01-29-2009, 07:14 PM   #5
PetersRedYaris
I'd say your fine at that interval...
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
Get your post counts here! *read 1st post for rules* Astroman Off-topic / Other Cars / Everything else Discussions 3414 11-04-2012 09:03 AM
Help with oil change specs autophile DIY / Maintenance / Service 31 04-25-2011 09:22 PM
Oil change time... yay! YarisFan007 DIY / Maintenance / Service 10 09-19-2007 05:40 AM
