Old 01-31-2009, 12:58 PM   #1
Tamago
Tamago's Avatar
Drives: UZJ100
on stock suspension or with a little bit of camber, you can easily run a +35 offset.. it'll give you a very nice flush look. 205 tire MAX though.
Old 01-31-2009, 03:27 PM   #2
Russelt3hPirate
l33t3st Asshole
Russelt3hPirate's Avatar
Drives: MY07 Yaris Liftback
although if you lower the car with the +35mm you run the risk of rubbing.
EDIT: why did you choose tenzo if you don't mind me asking?
Russelt3hPirate is offline   Reply With Quote
Old 01-31-2009, 03:32 PM   #3
Black Yaris
der Zeck
Black Yaris's Avatar
that is not true in the slightest, we can run pretty low offsets on Scions with out rubbing
I run 17x7 +18 front and +5 rear.... with 205/40R17.... I am lowered 3 inches, no rubbing problems.
Old 01-31-2009, 03:48 PM   #4
Russelt3hPirate
l33t3st Asshole
congrats, you have a scion xB.
does the OP?
I run a 15x7 +35mm on my YARIS and it rubbed when lowered until we put coilovers on. I have a feeling that's a little more applicable then your scion when regarding the OP's setup.
Although I could be wrong....
Old 01-31-2009, 04:01 PM   #5
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Scions + Low offsets = OK (I ran a +25 in the rear w/o problems on my xB)
Yaris + Low offsets = Rub.
I rubbed with a 15x6.5, +38, and 205/50/15s
I rubbed badly with a 16x7, +37, and 205/50/16s
Heck, I even rub a tad bit with +40 and 195/55/15. Granted, my front end is pretty low, but not that low.
Old 01-31-2009, 07:15 PM   #6
FA7
Drives: 2008 YR 5 door
went to the local showroom here in adelaide and loved the look of the black rims, non of the other black rims they had i thought looked good, if you can suggest other rims i am more than happy to look at them as i am always changing my mind
FA7 is offline   Reply With Quote
Old 01-31-2009, 08:15 PM   #7
Tamago
Tamago's Avatar
Drives: UZJ100
i recommend Team Dynamics (the racing line, not the "street line") an excellent UK-made wheel and comes in decent offerings for width and offset. simple designs, strong, and relatively lightweight
Offset and lowering on 205/45/16s driver centric Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 08-13-2016 10:09 AM
How to determine proper wheel offset? Yaris Revenge Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 05-23-2009 10:41 AM
offset... Keymaster Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 02-01-2007 01:53 AM
max width and offset? Fat Felixxx Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 06-08-2006 03:43 PM
Max offset riceboy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 05-01-2006 09:57 PM
