Old 02-02-2009, 06:46 AM   #1
Kal-El
Kal-El's Avatar
Originally Posted by PetersRedYaris View Post
I agree, but that's the US oil change interval... I find it very interesting that the European Yari have longer intervals, like Andies 9,000 mile (15,000 Km) recommended change from post #18. His TS has the same motor as the new Corolla, so whats the difference?
You have to question why US yari have shorter recommended oil changes compared to the rest of the world.
Yes, I'm quite curious to know why the intervals are different.
Old 02-02-2009, 09:40 AM   #2
TheSilkySmooth
TheSilkySmooth's Avatar
Drives: 08 3DR 5M Bayou Blue; 09 Fos
One thing, longlife synthetic meets a chem-E definition of 'synthetic' in the EU, so you have grp iv-v blends over there that have MUCH lower residue over a 15km interval where a "big USA Name oil" SM/SL would be 'toast'. rest assured though, Your Redlines and some Amsoils would compare favourably to the energy conserving EU oils. The Eu ACEA spec can be manufacturer specific, and A3/B3 is very conservative for HTHS viscosity;BMW lost a whole bunch of engines running underspec USA oils over here and spec only ONE Castrol very high weight oil. But Dont worry, EU typical citizen microcar EU manufacturers and producers will soon be following API/ISLAC for lower emissions and their engineer will be pulling hair. See the ACEA A1/B1. In fact we are running a French Motul 8100 that meets SL and a1/b1 and I can say its not too great, so they are already in the dumpster on changes. It will take time and a lot of engine failures before this gets settled. I bet in 2-3 years you will see something in news about bad oils if a new "wonder chemical additive" doesnt come out to replace the "banned' Zinc phosphates (zddp). I need to studythis big advance that Castrol is touting. - Papa
TheSilkySmooth is offline   Reply With Quote
Old 02-02-2009, 09:44 AM   #3
TheSilkySmooth
I am curious to know if the EU spec vehicles and those sold in NZ and Australia have differing piston and journal clearances to utilise the more viscous oils for long life intervals. You can't specify 5w-20 and 15W-40 in the same engine regardless of ambient temps. The engine temp is mainly determioned by the coolant thermostat.
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
Engine oil ddi not come out hans_fh DIY / Maintenance / Service 18 01-23-2009 11:30 PM
oil and oil filter question.. marcus DIY / Maintenance / Service 27 07-11-2007 03:25 PM
metal particles in oil 007 hatch DIY / Maintenance / Service 9 06-22-2007 02:56 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
