#37 | |
Drives: yw calls me douche and racist. Join Date: Aug 2007
#38 |
![]() ![]() ![]() ![]() Drives: 08 3DR 5M Bayou Blue; 09 Fos Join Date: Oct 2008
One thing, longlife synthetic meets a chem-E definition of 'synthetic' in the EU, so you have grp iv-v blends over there that have MUCH lower residue over a 15km interval where a "big USA Name oil" SM/SL would be 'toast'. rest assured though, Your Redlines and some Amsoils would compare favourably to the energy conserving EU oils. The Eu ACEA spec can be manufacturer specific, and A3/B3 is very conservative for HTHS viscosity;BMW lost a whole bunch of engines running underspec USA oils over here and spec only ONE Castrol very high weight oil. But Dont worry, EU typical citizen microcar EU manufacturers and producers will soon be following API/ISLAC for lower emissions and their engineer will be pulling hair. See the ACEA A1/B1. In fact we are running a French Motul 8100 that meets SL and a1/b1 and I can say its not too great, so they are already in the dumpster on changes. It will take time and a lot of engine failures before this gets settled. I bet in 2-3 years you will see something in news about bad oils if a new "wonder chemical additive" doesnt come out to replace the "banned' Zinc phosphates (zddp). I need to studythis big advance that Castrol is touting. - Papa
#39 |
I am curious to know if the EU spec vehicles and those sold in NZ and Australia have differing piston and journal clearances to utilise the more viscous oils for long life intervals. You can't specify 5w-20 and 15W-40 in the same engine regardless of ambient temps. The engine temp is mainly determioned by the coolant thermostat.
#40 |
![]() ![]() ![]() Drives: 2007 Toyota Yaris S Sedan Join Date: Jul 2007
like you said, "oil is the lifeblood of the engine". I have a yaris with over 300,000 miles on it. why? because I use synthetic oil and i still change 5000 miles or before. don't sacrifice your car's engine to save time or money or headaches! because in the long run it may cause you more time, money and headaches, if you damage the engine.
![]() http://www.youtube.com/watch?v=YnTlNLz9Iqc http://money.cnn.com/galleries/2010/...le_cars/5.html http://www.subcompactculture.com/200...-miles-on.html |
#41 | |
DWEED
Drives: 3DR 2008 Metorite Metalic Join Date: Oct 2008
Making a decision without following it with an action is still a fantasy. |
#42 | |
#43 |
Vroom Vroom Beep Beep
Atleast no one here has tried the Ams 25k mile oil yet. I use it in my Diesel truck once a year changes though its 9 years old and has 4k more miles than my yaris
Ever blown out an R-200 diff god know's I have
#44 |
Clean and (dis)Functional
Drives: Yaris 2dr--Black Betty Join Date: Mar 2007
I don't consider myself 'green' by any means, but (believe what you want on the longevity of the oil) if you change the oil at 15,000 miles the cost per mile (40 mpg / $1.90 per gallon / $25.00 for oil & filter) is $0.0491---oil change is 3.5 % of driving costs. At 10,000 miles oil change is 5.3%, and at 5,000 miles oil change is 10.5% of driving costs.
So.....If you believe 15,000 miles between oil changes is ok, You can save as much money or more than if you drive like a hypermiler. Or roughly you can drive an extra 500 miles for free if you extend your oil change by 5,000 miles (1,000 free miles if you change at 15k instead of 5k). Gamble at your own risk...my warranty is off now so I'm going for the 10,000 mile change.
____________ Old School Cobble Jockey
#45 |
I.. don't think cost is the issue here man.
#46 |
If cost is not the issue ... change every 1,000 miles! Guaranteed that your engine will have the best benefit of clean oil.
![]() The "facts" of oil performance are buried somewhere in reports by indpendant and not so independant labs. Everyone is free to pick the "facts" that they choose to go by. ![]() In the 60's I changed oil every 3,000 and engines were still sludged up. Now oils are so much different....the EPA mandating changes in additives for green concerns, is the main source of reduction of oil's effectiveness (trade offs).
#47 |
Are you even reading this thread?
#48 |
Sorta thought I was! The only reason to spend money changing your oil is to prevent spending a lot more money by changing your engine. Some people think 15k is fine for synthetics, and seems like someone mentioned an oil that claims 25k.
My warranty is up, I drive 30k a year, and my opinion is that I'll drive 5 to 10k before I change my synthetic oil. If you have a different opinion fine. Driving conditions vary for everyone, and that is a big factor. As far as 'factual' info on this, it's sort of like global warming, you will find supporting 'facts' however you think.
#49 |
Beast
Well.. The best you can do is tally up info from various cars knowing how often they were changed on a continued basis and see what happens.
![]() One you've taken a yaris for a spin, there's no turning back. Its a Chao!!! |
#50 | |
IMHO, I don't think oils have much to do with the change intervals. If the oils meet the minimum requirement, it'll then depend on how well made the engine is. Unless you're a Ferrari owner or something. Then that would be a different story. My mom's Nissan Quest went with out an oil change for 150k miles. Thats right, 150,000 miles. Thing ran like crap. My buddy and I had done a engine flush, twice, changed the spark plugs, and it ran like new. It was epic. Go VG30DE. |
#51 |
![]() ![]() Drives: 2009 Yaris 3 door M/T Join Date: Jan 2009
Here's my experience with oil changes for what it's worth (possibly nothing). FIY I have never used synthetic oils.
1986 Jeep Cherokee 289,000 miles at time of selling, 3K oil changes as recommended, never rebuilt or replaced engine, used many different brands of oil over the years. 1983 Mercedes 240D 394,000 miles at time of selling, 5k oil changes as recommended, no problems at all, used regular Castrol. 2000 Civic HB 222,000 miles at time of selling, 7k oil changes as recommended, no problems at all, always used standard Valvoline, still getting 38mpg when I traded it for my Yaris. Based on my past experience, I think the Yaris will do fine with 5k oil changes. Recommended oil change intervals for passenger cars are always set within a much larger safety range. Remember it's a recommendation, your car will not self destruct if you take it to 5,001 with no oil change, or 10k or even 15K (though I wouldn't suggest trying it). The Yaris is a well engineered, solidly manufactured, quality machine and that's a big part of the equation that often gets overlooked. It's built to last if well maintained. Consider how many oil changes you will do for each 100k miles - 33 times if you change at 3k or 20 times if you change at 5k. Consider how much you spend for each oil change. I do my own and it costs me about $25 each time including filter. That's $500 for every 100k miles with 5k changes or $$825 with 3k changes. I am personally not convinced that the extra expense of the 3k change is warranted for the Yaris. Based on knowing many long term Toyota owners, I just don't see any otherwise properly maintained Yaris blowing an engine at 150k even 200k because someone did 5k changes instead of 3k. These are just my opinions, based on my own real world experiences. Change your own oil as you see fit. To each, his own. Last edited by Havana; 02-04-2009 at 09:52 AM. |
#52 | |
![]() ![]() ![]() Drives: Yaris Hatch /Landrover D2 Join Date: Jun 2007
Good info, some Euro mfg go as long as 40,000 km to an oil change. in North America the BMW LL4 spec is over 20,000 km change, but you have to use a ACEA (euro) oil to meet the standard. THe VW TDi diesel is hard on Oil and the drain is 15,000 km, Better base oils and additives allow the longer drain intervals. The problem is that Canadian and US gas contains Methanol/ethanol which is hard on the oil. I go 12,000 Km with Euro oil with no problems, but would recommend following Toyotas suggestions if you want warrantee.
#53 |
![]() ![]() Drives: yaris Join Date: Oct 2008
can you use bmw genuine synthetic oil 5w-30?
#54 |
Drives: 2007 4 Door Yaris Join Date: Jan 2009
I change at 5k if I have money, but usually go 6-8k on mobil 1 synthetic.
And all this talk about the great german engineers.. Don't get me wrong, I'd pick up an M3 if I had the money, but every person I've seen with a beemer drives the dealer loaner more than their car... |
| DIY: CHANGE MANUAL TRANNY OIL | ttufrosty | DIY / Maintenance / Service | 157 | 09-07-2018 01:43 PM |
| Engine oil ddi not come out | hans_fh | DIY / Maintenance / Service | 18 | 01-23-2009 11:30 PM |
| oil and oil filter question.. | marcus | DIY / Maintenance / Service | 27 | 07-11-2007 03:25 PM |
| metal particles in oil | 007 hatch | DIY / Maintenance / Service | 9 | 06-22-2007 02:56 AM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 08:16 PM |
