Old 02-08-2009, 05:46 PM   #1
TheSilkySmooth
TheSilkySmooth's Avatar
Drives: 08 3DR 5M Bayou Blue; 09 Fos
Ha, Toyota got us on the other end: the valves are non-adjustable, non-hydraulic, and the whole top end of the engine (cam box) will have to be torn down periodically to adjust any valve that is out of the clearance spec. I'll put up with some clacking rather than go through this $700- service befor 100K miles. BTW, timing chain tensioner are historically very troublesome. I like belts! Gee, why does a Lexus LS430 V8 have timing BELTS? Give me a couple strong belts!
TheSilkySmooth is offline   Reply With Quote
Old 02-09-2009, 12:39 AM   #2
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Originally Posted by TheSilkySmooth View Post
... BTW, timing chain tensioner are historically very troublesome. I like belts! Gee, why does a Lexus LS430 V8 have timing BELTS? Give me a couple strong belts!
Not in Toyota's... And why would you prefer an expensive belt service over nothing required?
A lot of toyota engines, as well as most imports, used to use belts. Not anymore... Even the new 4.0 V6 (4-runner and FJ) and the new 5.7 V8 (Tundra) now use chains. In fact almost every new engine Toyota has uses a chain. Hell, even our 2006 Civic 1.8 has a chain...
And that's belt, not belts...
CHAINS FTW
PetersRedYaris is offline   Reply With Quote
Old 02-09-2009, 12:44 AM   #3
PetersRedYaris
http://www.toyota.com/help/faqs/serv...ing_chain.html
Model Year Engine Belt/Chain/Gear
4Runner 1990-2000 4 Cylinder Chain
1990-2002 V6 Belt
2003-2008 V6 Chain
2003-2008 V8 Belt
Avalon 1995-2003 V6 Belt
2004-2008 V6 Chain
Camry 1990-2001 All Belt
2002-2008 4 Cylinder Chain
1990-2006 V6 Belt
2007-2009 V6 Chain
Camry Hybrid 2007-2009 4 Cylinder Chain
Celica 1990-1999 4 Cylinder Belt
2000-2005 4 Cylinder Chain
Corolla 1990-1997 4 Cylinder Belt
1998-2009 4 Cylinder Chain
Cressida 1990-1992 L6 Belt
ECHO 2000-2005 4 Cylinder Chain
FJ Cruiser 2007-2008 V6 Chain
Highlander 2001-2007 4 Cylinder Chain
2001-2007 V6 Belt
2008 V6 Chain
Highlander Hybrid 2006-2008 V6 Belt
Land Cruiser 1990-1992 L6 Gear
1993-1997 L6 Chain
1998-2007 V8 Belt
2008 V8 Chain
MR2 1990-1995 4 Cylinder Belt
MR2 Spyder 2000-2005 4 Cylinder Chain
Matrix 2003-2009 4 Cylinder Chain
Paseo 1992-1997 4 Cylinder Belt
Previa 1991-1997 4 Cylinder Chain
Prius 2001-2008 4 Cylinder Chain
RAV4 1996-2000 4 Cylinder Belt
2006-2008 V6 Chain
Sequoia 2001-2007 V8 Belt
2008 4.7 V8 Belt
2008 5.7 V8 Chain
Sienna 1998-2006 V6 Belt
2007-2008 V6 Chain
Solara 1999-2001 4 Cylinder Belt
1999-2008 V6 Belt
Supra 1990-1998 L6 Belt
T100 1993-1998 4 Cylinder Chain
1993-1998 V6 Belt
Tacoma 1995-2008 4 Cylinder Chain
1995-2004 V6 Belt
2005-2008 V6 Chain
Tercel 1990-1998 4 Cylinder Belt
Truck 1990-1995 4 Cylinder Chain
1990-1995 V6 Belt
Tundra 2000-2004 V6 Belt
2005-2008 V6 Chain
2000-2008 4.7 V8 Belt
2007-2008 5.7 V8 Chain
Yaris 2007-2008 4 Cylinder Chain
For Timing Belts, please reference our "Timing Belt Recommendations" FAQ (Frequently Asked Question) to determine the maintenance interval recommendations.
For Timing Chain and Gears, there are no prescribed replacement intervals; these components should be replaced as needed.
Old 02-09-2009, 10:50 AM   #4
TheSilkySmooth
Oh sorry I'm an old subaru guy - we have 2 belts; one for each 2 cyl bank. I made the assumption that the toyota 4.7L v8 had 2 belts also.
My question to toyota designers, especially with the thinner oils utilised today wiith low EP adds, why no roller followers on the cam tappets (ala Mitsubishi) and why "non- adjustable without a extensive tear down? Gee I could easily adjust my 2.3L chevy vega inveted bucket tappet with a hex key and only remove the valve cover
Yaris TS 1.8L History and Specs CASTREX Yaris TS Talk 52 10-27-2009 05:06 PM
Test Drive: Yaris revolution ketel0ne General Yaris / Vitz Discussion 0 08-04-2006 10:13 AM
