stock head studs are not a good idea. We had to custom make a set, but there is a company overseas making them. Can't vouch for the quality though.
![]() ![]() ![]() ![]() Drives: Vitz RS Turbo Join Date: Nov 2008
http://www.microimageonline.com/foru...lts-yaris.html
You posted that the link doesn't work for you, but I just tried it and it came up ok.
#4 | |
Although I got some news that AJUSA head bolts are similar to standard Bolts or else equal. I will be probably getting them custom made from DP. What can you tell about porting? Is it worth doing it from experience? What is the average increased hp? What about Knife edging crankshaft? What are the pros and cons of it? What about doing upgraded sleeves? At what power they are really needed? Come on is only Garm helping here... where are the experts
I ♥ Yaris
Drives: Black 08 LB MT & red 97 Miata Join Date: Oct 2008
http://downforeveryoneorjustme.com/i...manceparts.net works for me and downforeveryoneorjustme.com says its up
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt. - Bertrand Russell |
I sleeved my Yaris block because we knew we were going for 20+ pounds of boost.
I would sleeve it if you intend to throw 15+ at yours. Porting/polishing increases airflow. The effect and increased hp is amplified when you throw boost at it (more air trying to pass through, obviously). I would do it. I am using stock crankshaft, and I like the results I'm getting so far.
#7 | ||||
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car Join Date: Oct 2008
Ok so porting will be one on my list.... Then what about stock valves and springs? Are they capable of 20+ boost?
I made some more research on knife edging the crankshaft. They usually make it on Honda engines but since it doesn't cost that much I would probably do it. RE: Sleeves... My Power intensions are somewhere near 300Hp. Considering that I am using a turbo GT28 and using street pump low grade octane fuel (Below 90) the engine would need about 25psi of boost to get into that range. The tuner said, if going to do sleeves, the pistons could need to be replaced to match new sleeves... so it would cost me a fortune to make this happen! |
hi parmas,
im too getting my head ported as well. at the same time, i fully agree with what garm said. the more air you could flow, the better. and results will be amplified when you boost it. you should go ahead and get a "head job" :) im also having my cams welded and grinded too, and the valve springs will be changed as well. as for the AJUSA bolts, i could only comment that the bolts are much more heavier than the stock ones. however, heavier does not mean they are better. i can only tell you this much, and until my cylinder head is back i don't have further inputs on that. im currently keeping my crankshaft stock though, tuner did not recommend me to have them knife edged so i did not pursue that.
454 whp, 1.7 bar boost, pump gas, water/meth. 501 whp, 2.2 bar boost, pump gas + avgas, no water/meth. www.viosturbo.com - World's first 500 WHP 1NZ-FE |
Thanks for the info changchewsoon
What valve springs are you intending to use? Regarding cams I think I leave them stock don't want to mess everthing at once RE AJUSA bolts, heavier doesn't meen better but the quality of metal used. Do you know if they match exactly the stock bolts? I mean no rethreading etc.. RE Knife edging crank, Did you asked your tuner the reason not doing it? |
#11 | |
reason why the shop that was working on my head changed the valve springs is because we told him that we wanted to increase the rev limit to at least 8,000 rpm or above. the AJUSA bolts does match the stock bolts, the only think im not able to comment is the quality until we use it. as for the knife edging crank, i did not asked him why we do not need to do it.
#12 | |
Keep us updated |
#13 | |
I'm about to tune upwards of 25 psi, on stock crank and stock valve springs. I just don't see the need to spend money there when it's not necessary.
#14 |
What fuel octane are you using Garm?
#15 |
91 with water/meth injection. Should be able to run 25 psi on pump gas.
#16 |
#17 |
Stock valve springs are designed to work with the stock rev limit and the stock lift and ramp angles on the cams. If you change any of those, only then do you need to look at a heavier valve spring.
#18 | |
| Motor Longevity | Pavel Olavich | DIY / Maintenance / Service | 10 | 03-17-2012 11:43 AM |
| cali yaris built motor | cali yaris | Performance Modifications | 83 | 09-03-2009 11:08 PM |
| Fan motor noise... | 500snakz | General Yaris / Vitz Discussion | 10 | 12-01-2008 02:43 AM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 08:16 PM |
| Exchanging Motor on a Liftback 1.3 Lt | weckjuan | Performance Modifications | 8 | 11-12-2006 10:58 AM |
