Old 02-13-2009, 04:13 PM   #1
kimona
kimona's Avatar
Drives: 2014 White VITZ
16x7, ET42, 205/50/16 will not rub on stock suspension... front or rear.
Old 02-13-2009, 04:50 PM   #2
Split
Drives: 2008 Yaris Sedan
Exclamation
suspension has nothing to do with it. it just means the factory springs/shocks have to be compressed an additional 1" before rubbing occurs. if you bottom out aftermarket suspension or factory suspension, you end up at the same height.
Split is offline   Reply With Quote
Old 02-13-2009, 04:54 PM   #3
Russelt3hPirate
l33t3st Asshole
Russelt3hPirate's Avatar
Drives: MY07 Yaris Liftback
strange. when I changed suspensions I stopped rubbing.
but you're right suspension has nothing to do with wheel fitment.
if you're lowered on aftermarket springs there is a chance you'll rub constantly (FYI, that's bad).
where if you were stock you'd only rub under heavy load.
that's the reason we ask.
some people are ok with little rubbage after serious dips.
Rub constantly = Bad
Rubbing only a little at certain times = ok for some people
not rubbing ever = good.
to determine such things knowing your suspension setup is a factor. :)
and a car on DF210s with a full hatch is very low. :lol:
Russelt3hPirate is offline   Reply With Quote
What are you doing right now? Bob_VT Off-topic / Other Cars / Everything else Discussions 26819 12-31-2010 10:48 AM
want 2 lower with tein but have tyre rub HELP! MR. CANTON Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 09-24-2007 04:16 PM
Got new wheels, tires, and springs installed. largeorangefont Wheels, Tires and Suspension Forum sponsored by The Tire Rack 44 09-22-2007 04:21 AM
