Hi Marty
if you look behind your grill you should see the orginal horn , Taped to it should be another set of wires to plug in a second horn . |
![]() ![]() ![]() Drives: 2008 5-door Yaris Hatchback Join Date: Oct 2008
Right on! I knew you would know something about this.
Did you happen to use this horn? |
#3 | |
the Toyota ones are the same just rebranded |
I had a look, and unfortunately there are no other wires taped to this area that look like they are for the horn. There is a thick collection of pink and white wires, but no green wire or connector for a horn.
#5 | |
![]() if you install these or something similar you will have to increase fuse size to at least 15 amp . |
I assume that is not as simple as just popping in a higher amp fuse? Won't the wiring burn in such cases?
#7 | |
| Genuine Toyota Hitch for Yaris now available in Canada | voodoo22 | DIY / Maintenance / Service | 8 | 04-22-2014 07:50 AM |
| Response from Toyota on my special order | drdavidr4u | New YARIS Purchase Forum | 14 | 04-27-2010 08:59 PM |
| Response from Toyota | Driver | New YARIS Purchase Forum | 22 | 09-04-2006 07:44 PM |
| Toyota Delays | Buckethead | General Yaris / Vitz Discussion | 3 | 08-26-2006 03:16 AM |
| Toyota Yaris to Sponsor FOX's "Prison Break" | YarisBueller | General Yaris / Vitz Discussion | 0 | 04-30-2006 08:01 PM |
