Old 02-15-2009, 10:40 PM   #1
Tamago
Tamago's Avatar
Drives: UZJ100
mass airflow sensor works by "measuring" the velocity and temperature of air that passes past the sensor. if you change from a 2" to a 3" pipe the MAF measures X amount of air and is actually receiving 30% more air. not sure that it would cause a CEL that quickly that's why i asked if you'd wired everything correctly.
Old 02-16-2009, 12:04 AM   #2
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
Since the tube is wider, I assume that the same amount of air that the engine consumes is moving slower past the MAF sensor. That may skew the temperature that is being sensed.
Old 02-16-2009, 02:13 AM   #3
Niko
Drives: 2008 toyota yaris sedan
well i went to check like you said and i found that it was a number of air leaks that were causing the sensor to not read correctly. I used a sealent to fix the leaks and just got back from i two hour drive and the car ran great and no check engine light.
Niko is offline   Reply With Quote
Old 02-16-2009, 02:15 AM   #4
Niko
thanks for the info guys. i really have no where else to go to get help for my yaris because my family is an american car family.
Simota Carbon Charger Cold Air Intake lilredrocket Performance Modifications 18 04-13-2009 03:16 AM
guess what I'm waiting for and how much I paid? Ric n Sov's Vitz RS General Yaris / Vitz Discussion 27 06-27-2007 07:36 PM
problem with cold air intake skc Canada 24 06-18-2007 07:34 PM
Cold Air Intake vs. Short Ram Intake nevermorez Performance Modifications 1 01-24-2007 04:25 PM
