Old 02-16-2009, 12:36 PM   #1
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
got an 08 tc which was in before and had motor/head replaced under warranty for a ticking noise in the valvetrain. customer is back 3 months and 15,000 miles later and now ALL of the valves in the head are bent?
Old 02-16-2009, 01:09 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
what weight of oil is he running?
wait.. you're coming to YARISWORLD for tech support?
Old 02-16-2009, 02:04 PM   #3
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
...and that's a problem because?
Old 02-16-2009, 04:39 PM   #4
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
Does the timing chain still have tension?
rob323 is offline   Reply With Quote
Old 02-16-2009, 04:45 PM   #5
Tamago
Tamago's Avatar
Drives: UZJ100
iirc the newer chain tensioners are oil pressure activated and ratcheting... so they'd take up any slack.. so yeah, you may want to check that the teeth on the tensioner are not worn off.. but i still sniff a mis-shift.
Old 02-16-2009, 04:50 PM   #6
Tamago
Tamago's Avatar
Drives: UZJ100
not as much a problem as a slight source of amusement to me.. because most of the 'knowledge' on this forum orbits around what offset wheel you can run without rubbing and what weight of oil you can/cannot run...
so a question about bent valves being asked here where the OLDEST yaris on the forum (US, anyway) is approaching 3yrs old.
Old 02-16-2009, 06:52 PM   #7
BLAZINBLUEVITZ
probably because any talk of STREET RACING or ripping around the twisties with a new part installed is off limits....
Amp with Stock Head? Boy Blue In Car Entertainment + Electronics (audio / video / alarm) 11 06-11-2011 11:53 AM
srs / airbag light after head unit install? KwonSau In Car Entertainment + Electronics (audio / video / alarm) 7 12-24-2008 02:04 AM
Req: Head unit suggestions. xed In Car Entertainment + Electronics (audio / video / alarm) 21 08-09-2007 07:38 PM
Does the non integrated head unit do any processing? ponieswhee In Car Entertainment + Electronics (audio / video / alarm) 1 05-07-2007 09:00 PM
human head in coffee beans wushumasterku Off-topic / Other Cars / Everything else Discussions 8 04-19-2006 11:39 PM
