#1 | |
wait.. you're coming to YARISWORLD for tech support? ![]()
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car Join Date: Oct 2008
Does the timing chain still have tension?
iirc the newer chain tensioners are oil pressure activated and ratcheting... so they'd take up any slack.. so yeah, you may want to check that the teeth on the tensioner are not worn off.. but i still sniff a mis-shift.
not as much a problem as a slight source of amusement to me.. because most of the 'knowledge' on this forum orbits around what offset wheel you can run without rubbing and what weight of oil you can/cannot run...
so a question about bent valves being asked here where the OLDEST yaris on the forum (US, anyway) is approaching 3yrs old.
#6 | |
| Amp with Stock Head? | Boy Blue | In Car Entertainment + Electronics (audio / video / alarm) | 11 | 06-11-2011 11:53 AM |
| srs / airbag light after head unit install? | KwonSau | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 12-24-2008 02:04 AM |
| Req: Head unit suggestions. | xed | In Car Entertainment + Electronics (audio / video / alarm) | 21 | 08-09-2007 07:38 PM |
| Does the non integrated head unit do any processing? | ponieswhee | In Car Entertainment + Electronics (audio / video / alarm) | 1 | 05-07-2007 09:00 PM |
| human head in coffee beans | wushumasterku | Off-topic / Other Cars / Everything else Discussions | 8 | 04-19-2006 11:39 PM |
