Old 02-16-2009, 01:45 PM   #1
1stToyota
1stToyota's Avatar
nor do i..
but if 100 people on YW say that 0w20 is ok to run, then its fact.. don't bother opening that thing in your glove box (owners manual) YW says it, it's true!
Or bother looking at the oil cap
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 02-16-2009, 01:48 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
WAIT, wait.. toyota puts information like that on the cap?
Old 02-16-2009, 02:24 PM   #3
SilverGlow
Drives: 2007 Yaris Hatchback
..or bother reading TSB's, that are published AFTER Toyota printed their caps....
SilverGlow is offline   Reply With Quote
Old 02-16-2009, 02:34 PM   #4
The Shape
Drives: 2007 Yaris Sedan
So is four quarts of Castrol 5w-30 way to much?? I checked it and it is over the full line a little bit , but not drastically.
The Shape is offline   Reply With Quote
Old 02-16-2009, 05:01 PM   #5
The Shape
No one knows???
Old 02-16-2009, 05:35 PM   #6
1stToyota
1stToyota's Avatar
No one knows???
It's not enough to really worry about.
but 3.5 to 3.7ish is what should be in there.
2008 Scion xD
Old 02-16-2009, 06:51 PM   #7
The Shape
Yeah but going strictly by Toyota's recommended specs (whis I have no problem with doing I used 5W-30) I should need 4.3 quarts of oil in my Yaris instead of the 3.5-3.7 you recommend. http://www.yarisworld.com/forums/goo...007yaris_s.pdf
Old 02-16-2009, 07:10 PM   #8
1stToyota
1stToyota's Avatar
I think it says more because that's actually a dry-fill, and you don't get it all out with an oil drain...some oil stays in the head, etc...even some oil stays in the pan if the drain plug isn't located on the bottom. Ever want to see how much oil stays in the engine try pulling an oil pump/oil pump housing...even the oil sending switch will be holding/blocking enough to put a big puddle of oil on the floor when removed.
2008 Scion xD
Old 02-16-2009, 03:11 PM   #9
1stToyota
1stToyota's Avatar
That say 5w-20 is for the Yaris, not 0w-20
2008 Scion xD
Royal Purple Transmission Fluid caveatipse DIY / Maintenance / Service 14 01-09-2010 03:02 PM
Aside the name,y is Royal Purple purple? Yawesh General Yaris / Vitz Discussion 6 01-10-2009 06:50 AM
AMSOIL vs Royal Purple IllusionX DIY / Maintenance / Service 44 12-02-2008 12:35 PM
Royal Purple FTW Nibs DIY / Maintenance / Service 11 09-28-2007 01:06 PM
Anyone familar with Royal Purple synthetic oil? Yaris_Fan DIY / Maintenance / Service 34 06-23-2007 12:29 AM
