#19 | |
Drives: 2007 Yaris Hatchback Join Date: Oct 2008
For the millionth time! See attached official Toyota TSB, and you will see that the Yaris 1.5L engine can use 20 weight. And yes, I've been using 0W-20 in my Yaris for the past 54,000 miles. Increase in MPG is just around 1% however. I use the light stuff so that it gets circulated quick during cold morning starts. Quick circulation means less wear and tear during the first start up. And it is during the first start up that 90% of engine wear happens. My engine does not consume any oil after 5,000 miles. The engine runs smooth and no strange sounds coming out of it either. |
#20 | |||
![]() It states 5w-20 NOT 20 OR 0w-20 Quote:
#21 |
i think you guys were all related to GW bush the way you fight over oil
lol
#22 | |
![]() I fight over what Toyota says is right for our motor...I don't like bad and maybe very costly advice being handed out. |
#23 | |
but if 100 people on YW say that 0w20 is ok to run, then its fact.. don't bother opening that thing in your glove box (owners manual) YW says it, it's true!
#24 |
Drives: Yaris Join Date: Jan 2009
I highly, highly suggest that one runs what the factory calls for in regards to viscosity and weight. Especially for those that have never owned a car that utilizes a timing chain configuration.
#25 | |
#26 |
Or bother looking at the oil cap
#27 |
WAIT, wait.. toyota puts information like that on the cap?
#28 |
yes, my oil cap says 5w30
#29 | |
ALL the oil brands that sell 0w-20 make the claim that that their oil is a great match for ANY 5w-20 application. AMSoil, Mobil1 and others make this claim. And you are dead wrong about California and 0w weight oil. Anytime the ambient temperature is below 40F one will IN FACt benefit from 0w oil. You are also very foolish to think that it does not snow in California. It does in fact. Film strength and viscosity have NOTHING to do with each other. And in fact, there are some 20 weights that provide film longer then heavier oils. What you fail to understand is that 0w-20 and 5w-20 provide the SAME protection at full operational temperatures. The difference is during the first morning start of the cold day. And if a 5w is fine, then a 0w will be too. This is true according to AMSoil, and Mobil1 and ALL other makes that make 0W oils. According to Toyota, 5w-20 can be used safely in a Yaris 1.5L engine. Now, that being true, one can ALSO use 0w-20, 0w-30 too for our Yaris engines, and this according to ALL the makers of 0w oils. It is too bad you behave like you know more about oil then Toyota, AMSoil, and Mobil1. |
#30 |
#31 |
![]() ![]() Drives: 2007 Yaris Sedan Join Date: Nov 2008
So is four quarts of Castrol 5w-30 way to much?? I checked it and it is over the full line a little bit , but not drastically.
#32 | |
#33 | |||||||
![]() Quote:
5w-20 and 5w-30, and that's the way it'll be until you can fully quote, exactly, a multi-viscosity recommendation of 0w-30 or 0w-20 for the Yaris in a Toyota TSB Quote:
![]() Show me where Toyota says that "0w-20" is okay to use in the 1.5 Yaris motor on the Toyota TSB...you can't include Toyota with AMSOIL and Mobil1 because they don't agree with Toyota. They list "0w-20" but Toyota TSB will not list "0w-20" for the Yaris 1.5...you drawing your own conclusions isn't good enough for me, I'll stick with Toyota TSB and owner's manual recommendations.
#34 |
#35 |
that must mean you can use Peanut butter instead of oil, since the cap doesn't designate specific oil weights!!
#36 |
| Royal Purple Transmission Fluid | caveatipse | DIY / Maintenance / Service | 14 | 01-09-2010 03:02 PM |
| Aside the name,y is Royal Purple purple? | Yawesh | General Yaris / Vitz Discussion | 6 | 01-10-2009 06:50 AM |
| AMSOIL vs Royal Purple | IllusionX | DIY / Maintenance / Service | 44 | 12-02-2008 12:35 PM |
| Royal Purple FTW | Nibs | DIY / Maintenance / Service | 11 | 09-28-2007 01:06 PM |
| Anyone familar with Royal Purple synthetic oil? | Yaris_Fan | DIY / Maintenance / Service | 34 | 06-23-2007 12:29 AM |
