![]() ![]() ![]() ![]() Drives: 2008 Black Sedan Join Date: Oct 2008
lol pretty sure he just forgot for a sec. I would love to see this kit on a dyno and not just numbers. A real video of it or just driving around. I never heard of PE before so still a bit skeptical about dumping this much into a sc kit that i cant even research properly.
#4 | |
You should see articles out on our kit in the near future on our QUAD-Charger (2x Turbo 2x Super Charger) in American magazines soon. Thanks for looking ![]() ![]() ![]() The dyno graph left shows: Stock power of 123.95 WHP With PE Turbo 192.06 WHP +68.11 wheel HP gain and +46.95 ft/lb of torque increase on a stock 2004 MRS Toyota 1ZZFE engine with 91 octane gas. Robert and his crew at MVP installed the Power Enterprise PE1215 IHI ball-bearing turbo kit on the car with impressive results. Contact Robert@MVP Motorsports for related inquires. Phone: 940 683 8282 www.MVPMotorsports.com Power Enterprise's best recommended tuning/installation facility in TEXAS USA. ![]() With a remarkable gain at 3000 rpm, MVP Motorsports was able to achieve an astonishing 28ft/lb of torque and 20hp at the wheel increase as shown on the graph. This translates to a light weight vehicle with enough pick up to give even a Porsche a good run for its money on a tight turn race track. The power increase can be equivalent to the downshifting acceleration of one and a half lower gears, also due to higher volumetric efficiency, on a cruising speed on highway, MPG should have greatly increased. Robert at MVP Motorsports also suggested to keep the knock sensor plugged in as stock, but just modify the wiring on the two O2 sensors pin#21(primal O2 sensor input) and pin#12 (Secondary O2 sensor input) at ECU unit as shown on the diagram left, disabling the primal O2 sensor input wire to the pin#21. http://powerenterpriseusa.net/Powernews/index.html |
nice research time
| Tags |
| blitz, boost, power enterprise, supercharger, turbo |
| kit to install power locks? | songa | DIY / Maintenance / Service | 21 | 02-12-2015 06:31 AM |
| What ever happened to the Power Enterprises kit? | ztrack157 | Forced Induction Forum | 6 | 01-11-2009 12:06 AM |
| The Advantages of Nitrous on an Engine | KCALB SIRAY | Performance Modifications | 7 | 01-02-2009 10:53 AM |
