Old 02-19-2009, 03:57 PM   #1
Yaribhini
Drives: Yaris
I can't think of a bigger waste of money than a K&N filter for a yaris. It has absolutely zero benefits and it's filtering capability is much, much worse than a paper element so you end up with a dirtier motor/throttle.
Yaribhini is offline
Old 02-19-2009, 04:09 PM   #2
firemachine69
School'er of hard knocks
Drives: Silver Yaris 4dr. HB
Yessir, but don't tell the Yaris fanatics that, how else would K&N make so much money?
firemachine69 is offline
Old 02-20-2009, 11:27 PM   #3
id3379
§†ęĄ¶‡Ћ-NCP96
id3379's Avatar
i've already noticed a tad bit better gas economy comparing results with my SG2, and considering it is lifetime guaranteed', by the time i change my filter twice with the gas ive saved after all those miles it will have paid for itself and more.
id3379 is offline
Old 02-21-2009, 01:27 AM   #4
blacksandiegovitz
Your mom goes to college
blacksandiegovitz's Avatar
Drives: 08 Vitz
Um, no ...
K&n filtration/cfm flow is the highest of any aftermarket filter(many winning baja/off-road/track vehicals used k&n filters) . I'm running a k&n drop-in but I hacked my stock air box and flipped it upside down , so the filter is facing up . I also have a vented hood, so its getting air from outside the engine bay , so in my application its works just as good as any sri for 30 bucks . I could see how you dont notice any gains with the filter in stock configuration .
blacksandiegovitz is offline
Old 02-21-2009, 01:56 AM   #5
id3379
§†ęĄ¶‡Ћ-NCP96
id3379's Avatar
Originally Posted by blacksandiegovitz View Post
Um, no ...
wow that's a interesting idea, can you take pics of your set up ?
id3379 is offline
Old 02-24-2009, 04:33 PM   #6
1stToyota
1stToyota's Avatar
One problem with the increased airflow, doesn't the MAF meter just readjust for it?
And if I had one I'd be worried about either using too much oil or not enough. I've been told that they can't harm your MAF but I know that's not always so. A Toyota Avalon owner had a brand new K&N dropin that must have been over-oiled enough that it set a code and couldn't get much over 50% calculated engine load at WOT, until I cleaned the MAF and switched to a WIX filter...code didn't come back and saw well over 80% calculated engine load at WOT on my scanner's datastream.
Maybe someday GreenFilter will come out with a P/N for our Yaris. Similar to a K&N, just a little different approach.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
1stToyota is offline
Old 02-27-2009, 10:10 AM   #7
33OH
Drives: '08 Yaris
You're not supposed to use ALL of the oil.
33OH is offline
Old 02-27-2009, 10:13 AM   #8
1stToyota
1stToyota's Avatar
It was a customer that pulled the filter right out of the box and straight into the airbox of his Avalon. He didn't add adrop of oil that wasn't already there.
2008 Scion xD
DIY Cabin Air Filter BailOut DIY / Maintenance / Service 105 06-20-2019 12:59 PM
Liftback Air Conditioning (Cabin) Filter info Snappy DIY / Maintenance / Service 24 10-01-2010 06:36 PM
Cold Air intake with k&n filter _S7V7N_ Performance Modifications 23 12-19-2008 02:36 PM
Nippon Oil Filter IllusionX DIY / Maintenance / Service 6 12-07-2008 02:00 AM
K&N 57i filter for TS 1.8 jim TS Performance Modifications 5 06-24-2007 05:00 PM
