there is a vid of wot i think,. post#90
![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Bayou Blue LB AT Join Date: Oct 2008
We'll just wait for YOUR WOT video after you install the Power Enterprise S/C.
aFe Intake | Blitz Supercharger | Megan Header | TRD Exhaust | NST Pulley Set TRD Shocks/Struts | Tanabe NF210 Springs | TRD Sway Bar | Motegi TRAKLITE wheels | Kuhmo Ecsta XS R1 Concepts slotted rotors | Carbotech 1521 brake pads | stainless steel brake lines | Seibon vented carbon fiber hood |
I used to have 1700 posts
im not going WOT till i upgrade the spark plugs and get the right pulley on. im not screwn up this car its my daily driver.
but noogie has the right idea, get your OWN supercharger and then you can go WOT all day long |
NO WOT cause his pulley might fall off and his wrong size 225/40/18's might just hinder performance even more.....
EVERYBODY EVENTUALLY COMES BACK TO YARISWORLD...... |
whooppee, are you experiencing pre-ignition? Kurokuma-kun is.
Lurker supreme!
I'm not. I don't think I ever have. What does a "knock" actually sound like?
2006 Red Blitzed RS 5-door |
clk clk clk clk clk. Sorta like that. You'd have to be there.
It kinda sounds like if you put a couple of pebbles in an empty Coke can and shook it. It happens mostly under heavy load.
sounds sort of like a knocking sound, hence the term knocking.
at least it sounded like a knocking coming from my dads grand national when it started knocking a year ago i think i am when i went to new jersey yesterday i was cruising down the highway with the s/c set on low (being the position the s/c engages at roughly 10% throttle) and at about 60mph to 65mph and throttle position at 5% to 8%, periodically i noticed my a/f ration go from the normal 14 to 16 the car was leaning out and then it would shoot all the way to 10 being rich then back to the normal 14. i need to upgrade the spark plugs that should solve that issue. so preignition is a problem but only when the s/c is engaged and usually on the low setting. plus when i start hauling ass the a/f gauge reads in the 10's pretty damn rich so spark plugs r being ordered tonight |
When I first installed my S/C, I thought that I was hearing knocking all the time. I took the car to Garm's shop and he listened while I rev'd the motor to WOT. The weird noise was coming from my belt area. I'm not happy that it's occurring but I'm glad it's not knocking like when I did not have 91 octane in the tank. The sound comes and goes. Who knows, one day one of the pulleys in that area will shoot off their shaft.
![]() Ahh, the joys of forced induction...wondering when something under the hood will disintegrate. ![]() Until then, it's a constant sh*t-eating grin.
Yeah, I hear a wierd growling sound when I have the A/C on. I'll know more when the weather gets warmer and I have to run it more. I'll ask Jo if she hears that too. I think she has a stick.
It's kinda disconcerting, huh? Good news is that nobody has had their car blow up... yet.
Sometimes I hear it when the blower is not engaged. Like when I'm parked and idling and have the hood open. It's only coming from the passenger side, somewhere along the path of the belt. Garm, Guillermo, and JR could not figure out where the sound was coming from.
One of us will solve it eventually.
If someone with a S/C doesn't know what pre-ignition sounds like, do this:
1. Drive until you're almost empty. 2. Put 2-3 gallons of the lowest octane gas into your tank. 3. Drive without boost for a couple of miles to get that 91 octane out of your fuel lines. 4. Roll down your window. 5. Boost at WOT... that nasty sound you hear is pre-ignition. Don't do this for more than a few seconds. 6. Fill up the rest of your tank with 91 octane.
I hope we're not scaring anyone away from installing the next Blitz kit.
![]() ![]() Drives: 2007 Yaris Supercharged Join Date: Nov 2008
yeah i got the same noise when i first installed my supercharger too... its only when ur at wot....u can hear that noise... then i filled my tank up with 91 octane and added octane booster to my tank.. and the noise is gone.....ive been adding octane booster everytime i fill up and i havent got that noise ever since...
Bathroom + Laptop = <3
hahaha your'e scaring me, if i ever get one, i hope it runs fine with 93 Octane here, if not i better find an ignition controller, because this ecu is giving me one hell of a time still...
hmm...very interesting.
For the record. I don't have any problems with pre-ignition right now. I use Shell V-Power every fillup.
You are just running lean right now, correct? Tc injectors will fix this? Did you change your sparkplugs?
| List of Boosted Yarisworld Members | whooppee777 | Forced Induction Forum | 262 | 11-23-2022 05:49 AM |
| BLITZ supercharger kits IN STOCK | cali yaris | Micro Image | 34 | 06-02-2012 10:31 AM |
| anyone with Blitz supercharger? | yrsdrgn | Performance Modifications | 52 | 08-24-2010 07:57 AM |
| Blitz Supercharger vendors | sdyaris | Forced Induction Forum | 32 | 09-18-2009 12:28 AM |
| blitz supercharger!!! | djgab101 | Australia | 4 | 11-20-2008 05:06 AM |
