#1 | |
§†ęĄ¶‡Ћ-NCP96
DWEED
Drives: 3DR 2008 Metorite Metalic Join Date: Oct 2008
I have had cars with a lot worse placements for oil filters than the Yaris. On an 88 Toyota truck I had a side mount filter and always spilt oil on the engine block while changing.
Making a decision without following it with an action is still a fantasy. |
![]() ![]() Drives: 2012 Nissan Leaf SL Join Date: Jul 2007
This is the best placement I have seen, outside of my Chevy 1500. The only thing that made my truck better was it had higher clearance and I could crawl right under it and there was a lot of room. However, I don’t need to put my Yaris on ramps either; I just reach under and take care of business.
Cheers, Ryan |
![]() ![]() ![]() Drives: 09 yaris Join Date: Mar 2009
I liked changing my old c20. It had the 292 and wit hot oil you could lay under that thing and have it drained and filter changed in 10 minutes unless you want every last drop to come out of it.
I think my hands are stronger than some peoples. When I would use jiffy lube it would either be stuck on or not even what I call hand tight. One thing to watch for when the filters were put on that tight is that the o ring cam all the way off the motor and is in one peace. I have seen a lot of them that ripped or were stuck. |
| Higher capacity oil filter???? | 2006fronty | DIY / Maintenance / Service | 29 | 01-06-2009 02:00 PM |
| Nippon Oil Filter | IllusionX | DIY / Maintenance / Service | 6 | 12-07-2008 02:00 AM |
| What about the oil filter???? | Driver | DIY / Maintenance / Service | 28 | 10-23-2008 11:45 PM |
| oil and oil filter question.. | marcus | DIY / Maintenance / Service | 27 | 07-11-2007 03:25 PM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 08:16 PM |
