Old 02-23-2009, 10:54 AM   #1
1stToyota
1stToyota's Avatar
Go back to posting #29
Originally Posted by SilverGlow View Post
You are an idiot!
I never said the TSB says it is okay to use 0w-20. It says Yarii can use 5w-20.
HOWEVER, I use 0w-20 and my UOA's prove it is not a problem.
You really do need to take some vitamins!
Liar, check your #29 posting on this thread where you claimed that I'm wrong and Toyota, Mobil and Amsoil are right...
But thanks for the backpedal, because on this very thread I asked if 0w-20 was okay according to Toyota's TSB and you jumped on the thread with your little TSB link pretending that it was some sort of proof that Toyota thinks 0W-20 is okay for the Yaris.
"ALL the oil brands that sell 0w-20 make the claim that that their oil is a great match for ANY 5w-20 application. AMSoil, Mobil1 and others make this claim.
And you are dead wrong about California and 0w weight oil. Anytime the ambient temperature is below 40F one will IN FACt benefit from 0w oil. You are also very foolish to think that it does not snow in California. It does in fact.
Film strength and viscosity have NOTHING to do with each other. And in fact, there are some 20 weights that provide film longer then heavier oils.
What you fail to understand is that 0w-20 and 5w-20 provide the SAME protection at full operational temperatures. The difference is during the first morning start of the cold day. And if a 5w is fine, then a 0w will be too. This is true according to AMSoil, and Mobil1 and ALL other makes that make 0W oils.
According to Toyota, 5w-20 can be used safely in a Yaris 1.5L engine. Now, that being true, one can ALSO use 0w-20, 0w-30 too for our Yaris engines, and this according to ALL the makers of 0w oils.
It is too bad you behave like you know more about oil then Toyota, AMSoil, and Mobil1."
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 02-24-2009, 11:28 PM   #2
SilverGlow
Drives: 2007 Yaris Hatchback
Thumbs down
You are wrong again! I didn't backpedel because there is no need to.
Toyota's 800 customer service line says you CAN run M1 or AMSoil 0W-20 as these do meet all their criteria for Yarii engines. The TSB published came out AFTER they drew this conclusion. Call Mobil1 and AMSoil and see if you know more about oil then they. You don't.
And I certainly would never run an oil that would damage my engine for grins or giggles.
SilverGlow is offline   Reply With Quote
Old 02-25-2009, 08:28 AM   #3
1stToyota
1stToyota's Avatar
Exclamation I never said the TSB says it is okay to use 0w-20. It says Yarii can use 5w-20.
Really?
Toyota says to use "AMSOIL" even when it's NOT API approved?
AMSOIL's XL series is API approved, but it doesn't come in 0w-20
They require API approval and AMSOIL's 0w-20 isn't API approved.
OH, I see...the TSB came out AFTER, and not before And the TSB says do NOT use 0w-20 in the Yaris, gotcha! :)
They don't know enough or they wouldn't go against what Toyota wants to see in their Yaris crankcases.
Of course you would to get that extra mpg...in a southern California climate that doesn't need better than 5w, any better than what Toyota recommends, especially if you're running synthetic.
2008 Scion xD
Royal Purple Transmission Fluid caveatipse DIY / Maintenance / Service 14 01-09-2010 03:02 PM
Aside the name,y is Royal Purple purple? Yawesh General Yaris / Vitz Discussion 6 01-10-2009 06:50 AM
AMSOIL vs Royal Purple IllusionX DIY / Maintenance / Service 44 12-02-2008 12:35 PM
Royal Purple FTW Nibs DIY / Maintenance / Service 11 09-28-2007 01:06 PM
Anyone familar with Royal Purple synthetic oil? Yaris_Fan DIY / Maintenance / Service 34 06-23-2007 12:29 AM
