Old 02-26-2009, 02:47 PM   #1
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
it is either your switch , or the earth wire from the switch has a break in it .
Also try returning your day time running lights to factory operation.
as yellow wire under steering wheel (pin 3) should not have power on it
when ignition is turned off
remember i told you how to make a simple switch (over the phone) using a light bulb
and the relay turned the fogs on and off ,(useing pin3 and earth) try replacing the earth wire on your switch
also diconnect the pink wire you have attached to the green wire in your
consol and leave it disconnected for know.
If this fails buy a simple switch with a led on it connect it to the earth
and too the yellow wire ( pin 3 under sterring wheel) similar to what i talked you through on the phone .
and just in case you want to phone i am away this weekend , with my boy's. sorry i am not of more help.
Fog light install 07yaris_fe Cosmetic Modifications (Exterior/Interior) 10 07-20-2010 01:18 PM
Looking for the Toyota Fog Light install RocknRollRon DIY / Maintenance / Service 33 06-13-2010 06:46 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
Before I start calling around: fog light install prices St_G Cosmetic Modifications (Exterior/Interior) 4 03-17-2007 09:45 AM
