Old 02-26-2009, 10:13 PM   #1
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Originally Posted by Yaribhini View Post
Interesting that almost everybody missed the point that I tried to make and that is not that the K&N flows less than paper media, it is that it does so at the cost of filtration. A K&N let's more in which constitutes a dirtier motor and throttle body. I'd love to hear the arguments for needing more airflow for this 100hp air pump. Please don't kid yourself into thinking that the K&N is giving you better results. The only think that it's doing is making your motor and throttle dirtier.
You are actually wrong... Paper filters let very fine dust right through that coats the inside of the intake tube and can easily be seen when replacing the filter. An oiled media on the other hand catches all that fine dust and traps it. The inside of the intake tube on my Tacoma looked like it was removed from a brand new truck, and that was after 50,000 miles without cleaning the K&N. Trust me, they work, even in harsh conditions...
As for the MAF, I have personally over oiled a K&N filter and caused a CEL. But cleaning the MAF is SIMPLE (using CRC MAF cleaner, don't EVER touch the element with a q-tip) and disconnecting the battery resets the light. No harm done.
Compared to a stock paper filter, K&N's are better in every way...
PetersRedYaris is offline
Old 02-27-2009, 08:47 AM   #2
1stToyota
1stToyota's Avatar
It's an approved cleaning method on Identifix, unless someone isn't born with dexterity and nerve endings, and is real sloppy.
Paper doesn't invite gunk buildup on the MAF quite as well, causing a 10-20hp loss at the wheels instead of about 1hp gain at the wheels, if you're lucky.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
1stToyota is offline
DIY Cabin Air Filter BailOut DIY / Maintenance / Service 105 06-20-2019 12:59 PM
Liftback Air Conditioning (Cabin) Filter info Snappy DIY / Maintenance / Service 24 10-01-2010 06:36 PM
Cold Air intake with k&n filter _S7V7N_ Performance Modifications 23 12-19-2008 02:36 PM
Nippon Oil Filter IllusionX DIY / Maintenance / Service 6 12-07-2008 02:00 AM
K&N 57i filter for TS 1.8 jim TS Performance Modifications 5 06-24-2007 05:00 PM
