Old 02-27-2009, 01:39 AM   #1
Spades
The Hated One
Spades's Avatar
Drives: 07 White Manual Sedan
super charger would cost WAY more than I want to spend. I can source the intercooler, BOV, boost gauge and coolant & oil lines and other goodies I need for a couple hundred bucks(a perk to working at a auto repair shop and dealing with parts companies all day). the turbo i can source for 100 bucks, and i can also easily source the charge piping and couplers.
i have the equipment and ability to fab what i need for the manifold...so, the project should cost somewhere around 300-400 dollars. I dont think i can pick up a supercharger for that kind of money. whats more, superchargers are parasites. they use power to make power...which means gas milage loss. low boost turbo applications add milage when you arent hot rodding it.
so...my questions remain. what is involved to get oil to and from the turbo, and is there a better suited small turbo for a 5psi aplication, and would using the factory manifold and just building a flange to couple it be a bad idea? i wouldnt think a 5psi turbo would create enough back pressure to blow gaskets.
Old 02-27-2009, 01:48 AM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
i'm running 10psi on a VF39 from an sti, no issues with blowing exhaust manifold gaskets
and turbos DO hurt low end performance, as they are a restriction to exhaust flow.. anyway... semantics
your only issue with hanging a turbo off the stock manifold would be weight and room to work.. and then you have to deal with piping.. look up the greddy kit for the xB it has some retarded looking piping on it. a sidewinder would definitely suit the yaris (put the turbo where the battery/airbox is now) or top mounted like my setup, as you yarii owners have more engine-to-hood clearance than the xA.
so Hard to find Stock YARIS rims! Yawesh General Yaris / Vitz Discussion 3 01-18-2009 05:55 PM
Anyone find out how to turn off the seatbelt chime? overboost General Yaris / Vitz Discussion 54 11-22-2008 10:07 AM
Where to find Great Canadian Tire Deals? DreagonR Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 10-23-2008 12:06 AM
Help - find link nqd Off-topic / Other Cars / Everything else Discussions 3 08-29-2007 08:09 PM
