Old 09-19-2006, 08:48 PM   #1
overboost
Drives: yaris
Anyone find out how to turn off the seatbelt chime?
i downloaded the service manual and still can seem to find out how it is done can anybondy help me out.
overboost is offline   Reply With Quote
Old 09-19-2006, 09:05 PM   #2
Yaris
Yaris's Avatar
Drives: 2010 LB Meteor Metallic
You can't disable it without a scan tool. I had mine disabled for free.
Yaris is offline   Reply With Quote
Old 09-19-2006, 09:37 PM   #3
overboost
Drives: yaris
so just go to the dealership and ask them to do it?
Old 09-19-2006, 10:04 PM   #4
ketel0ne
ketel0ne's Avatar
Drives: 2007 Liftback Blazing Blue
Our dealer in Tysons Corner, Va. said no. :(
ketel0ne is offline   Reply With Quote
Old 09-19-2006, 10:07 PM   #5
overboost
Drives: yaris
why?
Old 09-19-2006, 10:45 PM   #6
ketel0ne
ketel0ne's Avatar
"They weren't allowed" no reason given, I felt like I was 5.
Old 09-19-2006, 11:03 PM   #7
thewifesyaris
thewifesyaris's Avatar
Drives: 2007 and 2008 MM Yari LBs
the chime makes sure that you buckle up, so when, if, a bigger vehicle, basically every other vehicle, hits you, or you hit another vehicle, you stay in your seat. if you dont like your seat belt for dumb reasons what-so-ever you could always get a motorcycle and kill yourself on that just as easy.
Two Yari on home!
thewifesyaris is offline   Reply With Quote
Old 09-19-2006, 11:07 PM   #8
03Z33
03Z33's Avatar
Drives: TCR10
Scan tool is the easiest way, or you can unplug/cut the wire goint to the seatbelt and short it out. This will make it think that the seatbelt is always clicked in.
03Z33 is offline   Reply With Quote
Old 09-19-2006, 11:08 PM   #9
ketel0ne
ketel0ne's Avatar
You obviously never use the passenger seat for anything but a person.
Old 09-19-2006, 11:11 PM   #10
ketel0ne
ketel0ne's Avatar
Ok, on the scan gauge I can send the obd-II port messages, now what?
Old 09-19-2006, 11:41 PM   #11
03Z33
03Z33's Avatar
Drives: TCR10
scanguage only communicates with engine... you need an actual Toyota scan tool to communicate with other control units such as SRS, ABS, HVAC, Seat belts, etc...
Old 09-20-2006, 12:21 AM   #12
overboost
Drives: yaris
easy there big guy, the reason that i want this disabled is because i cant have my books or backpack on the seat without the thing causing a rawkus. And for your information i also own a motorcycle and have yet to kill myself on that.
Well looks like i will have to contact the dealer with the problem and see what i can have done. if they wont touch it then i will just wire it so it allways thinks the belt is plugged in, nothing bad will happen except that if my passenger doesnt have there seat belt on it wont notify me, this i can live with.
Old 09-20-2006, 04:22 AM   #13
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
Ιf you can stand the noise for 2 minutes, it then goes off.
Old 09-20-2006, 06:25 AM   #14
H8SGAS
H8SGAS's Avatar
Drives: Black Liftback
Yup I agree with Katana, I have the same prob with gym bag/backpack setting it off. Though annoying it stops by the time I leave my street.
Well if it’s not a hybrid how do you get such good mileage?
H8SGAS is offline   Reply With Quote
Old 09-20-2006, 07:08 AM   #15
ketel0ne
ketel0ne's Avatar
Not to beat a dead horse but, if the weight shifts it reactivates it. I have had it go off 4 times in a 1 hour commute.
Old 09-20-2006, 07:15 AM   #16
H8SGAS
H8SGAS's Avatar
Sounds like you should kill that annoyance then!
Old 09-20-2006, 08:59 AM   #17
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
......or you can unplug/cut the wire goint to the seatbelt and short it out. This will make it think that the seatbelt is always clicked in.
doesnt work.... this is what i thought to do;there must be a relay/chip in the acutal seat belt...
I personally buckel all the time, but it is annoying when I'm working on stuff (cleaning interior, ect) and i have the car on so I dont wear the batt down and the shit dings for 12+ secs....
maybe I just made bad contacts with the wire... I'll try this again either tonight or tomorrow and let you guys know.
will work for parts
Old 09-20-2006, 09:36 AM   #18
03Z33
03Z33's Avatar
Drives: TCR10
sometimes it takes a 2 ohm resistor in-line...
Turn signal bulbs casterqc Cosmetic Modifications (Exterior/Interior) 2 07-15-2006 07:44 PM
Seatbelt warning annoyance! asa805 General Yaris / Vitz Discussion 5 06-30-2006 07:06 PM
