Old 03-01-2009, 11:54 PM   #1
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
very good idea. anything to save from killing the battery is good. one thing though...do you not have the annoying beep that reminds you they are on when you shut the car off?
mikenacarato is offline   Reply With Quote
Old 03-01-2009, 11:59 PM   #2
silver_echo
ekodrvr
silver_echo's Avatar
on mine, it only beeps when the door is open and the key is out
silver_echo is offline   Reply With Quote
Old 03-02-2009, 12:07 AM   #3
Mine Has the beep, but my Subaru had the auto off lights, and I really got used to having it that way.
There was a recent thread where someone's hearing impaired spouse kept leaving the lights on and killing the battery. That got me thinking about this mod, and it turned out to be pretty simple.
Old 11-16-2009, 05:56 PM   #4
Reeves360
Drives: 09 Yaris Sedan, 91 ToyotaTruck
Send a message via AIM to Reeves360 Send a message via MSN to Reeves360 Send a message via Yahoo to Reeves360
Light off when Key is Removed w/ Fogs???
My 89 Camry LE had this option as well. :P
I was wondering if I added the fog lights with the OEM fog light stalk if this would still work for me or will I have additional steps other then what was listed above?
Thanks for the help Scott!
Reeves360 is offline   Reply With Quote
Old 11-16-2009, 06:12 PM   #5
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Yes it will as the fog lights only come on with the head lights on or park lights . when useing the factory stalk .
Old 11-16-2009, 06:57 PM   #6
Exactly. I have fogs installed as well, and as 1NZ mentioned they do turn off with the key as well as the headlights.
Old 11-16-2009, 07:15 PM   #7
Reeves360
Thanks CTScott! I'll have to do this when I install my fog lights next month. I'll also be installing that switch that allows you to control your windows with an OEM or aftermarket alarm.
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY: Yaris LB Halo Led Projector Headlights goku87 DIY / Maintenance / Service 37 11-15-2013 06:23 AM
need pinout of ignition switch mikenacarato In Car Entertainment + Electronics (audio / video / alarm) 8 12-25-2008 10:20 AM
Ignition switch heats up kurokoma-kun General Yaris / Vitz Discussion 11 06-19-2007 02:53 PM
