Old 09-25-2006, 03:35 PM   #1
rarmogan
Drives: Toyota YARIS Liftback
Exclamation -- Liftback Rear Speaker Removal? --
PLEASE HELP!!
I would like to know how to remove the rear speakers on a 07 Yaris Liftback? Does anyone have some pictures or ideas on how to do this? Thank you for your time.
Ravi
rarmogan is offline   Reply With Quote
Old 09-25-2006, 03:42 PM   #2
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
heres a link to the manual Click here
also try doing a search on "rear liftback speakers" or "lift back speakers" or simply "remove speakers" you should finds a ton of threads on the subject, with photos
will work for parts
vodkalush is offline   Reply With Quote
Old 09-25-2006, 03:48 PM   #3
bigsky2
Cousin Vitz
bigsky2's Avatar
New users should search....
The rear panels in thd 3DR hatchback need to be removed first.
Remove the B-Pillar garnish by disengaging the clips.
Then remove the rear Panel by disengaging the clips that hold them in place, take out the panel.
Your rear speaker is held in place by rivets.
Take a drill bit and drill out the rivets.
Alternatively you can pry them out, but this will damage your stock speaker/bracket unit.
PS - You can't just stick another speaker in there after, you will need custom spacers.
DIY 07 Sedan Rear Speaker install vodkalush DIY / Maintenance / Service 32 10-20-2017 03:40 PM
yaris liftback rear seats folding flat? chibianh General Yaris / Vitz Discussion 6 06-02-2006 12:10 AM
