#1 | |
Modded Moderator
For comparing results, it would have been better to do it back to back. Keeping all variables as close to the same condition as possible is important for such a comparison. Closing the hood would be good too.
#3 | |
![]() ![]() ![]() ![]() ![]() Drives: Yaris Sedan Join Date: Sep 2006
I Drive a 129whp Yaris ;) |
Drives: 09 jetta tdi dsg Join Date: May 2010
The kind that only ones imagination can produce :P oEM ftw lol
In a world... where things squeak, wont fit,start to bleed, or are just plain hard to do.... ArmorAll will fix that
Modded Moderator
That is simply not true, sorry.
Here is a simple article about the difference: As pulled from articlebase.com Short Ram Intake The typical short ram intake is designed with a few key points. First, it has to be easy to install, and typically only requires standard hand tools. Second, it has to increase horsepower while being a relatively inexpensive modification. A short ram intake is called a short ram because it literally is short. The pipe typically is only about 12 to 18 inches in length, and has an air filter on the end. Short Ram Intake: Chambered Intake Kits There are short ram intake kits such as the Weapon R Secret Weapon that offer special technology designed to improve air flow to the engine with technology and tricks that the manufacture claims can out perform a cold air intake. These intakes however are typically as expensive as a cold air intake, except you do not need an air bypass valve. The Weapon R Secret Weapon features a built in tube that increases suction and velocity so the manufacture claims increased performance gains over standard short ram intakes. This is a chambered intake kit. Another chambered intake kit that is very popular is the AEM V2 Intake. Cold Air Intake The cold air intake is designed to increase horsepower by relocating the air filter outside of the engine bay, typically putting it into the fender. Because the air filter goes into the fender, the cold air is harder to install, but as it's name implies, it allows the engine to take in cooler air, producing more horsepower. Because of the extra complexity of the cold air intake, it typically has higher cost over the compariable short ram intake. Another issue for some, is that the cold air intake could sit low, and suck up water when running over water puddles. This causes hydrolock, and destroys the motor. There are air bypass valves which fix this, but that adds about another $50 in cost to the cold air intake. |
#7 | |
One may even call it slight sarcasm :)
PUERTO RICO ?!?!?! LOL - Yikes. I hear it's nice there, but never been. I was thinking of the crazy heat wave we have going on in Cali right now. :(
I have the injen sp series and works great very reasonable price
Machinist
Drives: Yaris sedan 2010 Join Date: Sep 2010
Hi, i don't want to start a new thread about this. But if you guys know... Quebec city have long and snowy winters... Well my question is: Can i use an AFE intake during winter season?
Awesome!
Drives: 12 Yaris/07 yaris Join Date: Dec 2010
so... im not sure if anyone knows how you would get hydrolock....
yo have to completely submerge the entire air filter.... the only way you would achieve this is if you planned on trying to float your yaris. you would be surprised how much water your engine could handle. i like the looks of the afe yes, but i would have to take the aem for the true cai! |
Winterizing
Drives: 2010 Toyota Yaris Hatchback Join Date: Oct 2011
I'm not happy with the afe
33.7 mpg in PA
#13 | ||
Winterizing
I have a post about my problems I've had with it. I'm not done trouble shooting it but I think that in the end I am going to have to do something drastic to get it to work like use jb weld to make sure all the seals are good. Here is a link to my post
http://www.yarisworld.com/forums/showthread.php?t=37315
33.7 mpg in PA
![]() Drives: 2010 Black Yaris Lb Join Date: Apr 2010
I'm using the AFE and I've been very happy. Nice bump in power and a great sound. Its also extremely easy to clean the Pro dry S filter media.
#16 | |
Winterizing
Did you ever have to do something extra to make sure all parts are sealed? Could you post a couple pictures of your connections please?
33.7 mpg in PA
| DIY - AEM CAI (cold air intake) | kurokoma-kun | DIY / Maintenance / Service | 4 | 08-16-2009 02:56 AM |
| Simota Carbon Charger Cold Air Intake | lilredrocket | Performance Modifications | 18 | 04-13-2009 03:16 AM |
| AEM Cold Air Intake!!! | BulletProofAuto | Sponsors Classifieds Area | 18 | 09-19-2006 09:33 PM |
| AEM Cold Air Intake | Toddhata | Performance Modifications | 18 | 08-08-2006 03:02 PM |
