Old 03-19-2009, 02:19 PM   #1
Tamago
Tamago's Avatar
Drives: UZJ100
Originally Posted by regal View Post
IMO one of the best cars ever sold was the old civic VX, it did an honest 50 mpg.
It had really tall gears.
I am planning on adding a LSD to my Yaris to help in the snow and was wondering if it is possible to buy a taller final drive ratio for the manual tranny ?
the gears from an ECHO transmission may work, but you're better off buying a complete transmission.
PM MORGAN about the issues she had trying to swap transmissions.
1. mounts are different
2. shift linkage is different
etc etc
also keep in mind, the yaris uses an 8 bolt ring gear, and echo is 6bolt ring gear so you'd need to buy an echo LSD if you're gonna use it on echo final gears.
yaris final drive: 3.72:1
echo final drive 3.53:1
Old 12-25-2009, 12:26 PM   #2
Yaryaryaris
Yaryaryaris's Avatar
Drives: 2007 Yaris HB 5-spd
etc etc
Please forgive my resurrection of this thread, but I've been interested in a taller final drive on my 07 HB manual. I remember my 00 Echo manual cruising at much lower RPM's, while my Yaris always seems to be dragging itself along with short, quick ratios.
I also monkey with 1st gen Metros (XFis) and the taller final drive in the XFi is probably the #1 reason they get far better MPG's than the base model. If the echo could be a trans/final drive donor I would be interested in doing it.
Has anyone had any experience with this since this thread was hot?
Thanks,
Brenton
I can see for Miles and Miles...
Yaryaryaris is offline   Reply With Quote
Optimal RPM for shifting Gears ? JapRulezz Performance Modifications 8 03-07-2009 04:16 AM
gears of war 2 ROCKLAND TOYOTA Off-topic / Other Cars / Everything else Discussions 25 02-16-2009 10:33 PM
Transmission versus Gears caveatipse General Yaris / Vitz Discussion 3 09-23-2007 03:50 PM
Engine Run-on changing 1st/2nd Gears Ferret_san General Yaris / Vitz Discussion 4 09-06-2007 12:21 AM
Gears bulldogs2k Performance Modifications 17 07-26-2006 08:16 PM
