![]() ![]() ![]() ![]() Drives: 2008 meteorite hatchback Join Date: Nov 2008
The electronic climate control displays
I know these are available in Russia and Australia and probably other countries, but not the US. Is there anyone out there who lives in a country where these are available?
For those people who do live in such a country, what do you think of the idea of being able to provide people in other countries these digital climate control clusters? I know I'd buy up a set and their required accessories (like a new air box, wiring, etc) faster than Superman can run.
- HOOOEY! That's one tahny little cawr! What the heck kinda toy is that? - A Toyota Yaris - A whut Yaris? |
╚══════════RN
+1 for curiosity's sake.
we have a digital cluster... not sure what you mean by climatic controlled ones???
Our digital clusters dont even have a climatic control or a temp monitor btw
The Fit is NO!
Drives: '09 3DR "S"|'87 Caddy Brougham Join Date: Dec 2008
He is talking about the auto climate control equipment, not the clusters. I have wanted to do this mod from the very first second I layed my eyes on a euro-yaris with that accessory.
LOOK AT THIS TOPIC I ALREADY POSTED ON THIS MOD FOR INFO. http://www.yarisworld.com/forums/showthread.php?t=11826 I REALLY WANT THIS MOD to happen! As soon as I get my yaris, I will be working on all three things mentioned in my post.
My OTHER car ![]() Please ignore the Ferrari
Yeah, that's exactly what I was talking about. We just need to find a couple of people from a country that does have this option to purchase the set from a dealer and sell it to people who really want it, like me and computerlove87.
Let me do some research. I am working on getting some other parts from Europe now, so I will try to assess if the climate controls are compatible with our AC system and if so, will get part numbers and prices.
I don't think anything would make me happier then being able to select a temperature, instead of constantly fidgeting with the dials... |
#7 | |
I know the new Volkswagen Rabbit isn't compatible with the GTI/R32's digital climate control; you'd have to replace the air box and some air hoses and obviously some wiring. When I was thinking of buying a Rabbit, I looked into the price of a total swap. For Volkswagen parts it cost $930 not including labor. These are Toyota parts, so it should be significantly cheaper :D
![]() ![]() Drives: Vitz RS 1.5 Join Date: Feb 2009
I don't mind helping if you all want something from Japan.
^does Japan have the digital climate controls?
Actually, Japan may be a better place to start. Here are the parts that I believe are needed for the conversion (if you could check on pricing/availability for us):
55900-0D210-B0 Control Assy, Air Conditioner (This is the entire center dash assembly including the "knobs", electronics, and trim) 87106-0D020 Servo Sub Assy, Damper (For Airmix) 87106-0D040 Servo Sub Assy, Damper 87106-0D030 Servo Sub Assy, Damper (For Mode) (These three replace the manual dampers with ones which are controlled by the above part) 82212-52020 Harness Assy, Air Conditioning, LHD (I believe that this is the entire cable assembly, including connections to the above and below parts) 88625-47031 Thermistor Cooler (Solar Sensor) (Sensor mounted under upper dash) (This part is available in the US, as it is used on many other cars) 88625-22131 Thermistor Assy (Sensor mounted in front bumper) 88625-47021 Thermistor, Cooler (Sensor mounted behind AC controls) (This part is available in the US, as it is used on many other cars) 88650-0D160 (This is the AC control module, which is mounted to the bottom of the AC assembly) |
I wonder if there are any Toyota mechanics out there that would be able to confirm that these are all the parts we need, or if we're missing anything? I'm surprised that there aren't like a hundred different parts, but rather relieved.
![]() ![]() ![]() ![]() Drives: '07 Yaris HB Join Date: Apr 2006
I'm still wondering about the digital speedo cluster.
#13 | |
This is what you want right ??
Can we confirm that that list contains all that we need? That we're not missing anything?
Guy Next Door
Feint..how much this stuff in yen currency?. can put on sedan?
My account just got hacked last year. ![]() starting back on Oct '08 |
The sedan uses a different "Control Assy, Air Conditioner" for the automatic climate control. I have not been able to find the part number for the Sedan (Belta) version.
| Digital Gauges, Auto Climate control, Manu-matic shifter | computerlove87 | Cosmetic Modifications (Exterior/Interior) | 21 | 12-02-2012 11:55 PM |
| Cruise Control - Again! | CB900F2 | DIY / Maintenance / Service | 47 | 06-17-2010 06:29 PM |
| Yaris 09 climate control lights | alt_k1ll3r | DIY / Maintenance / Service | 2 | 11-11-2008 10:19 PM |
| Bulbs For Behind The 3 Climate Control Knobs | razzorjet2 | DIY / Maintenance / Service | 2 | 04-06-2007 10:41 AM |
| US Speedo and Climate Control swap | Master | General Yaris / Vitz Discussion | 3 | 06-02-2006 12:56 AM |
