Old 03-25-2009, 08:49 AM   #1
Let me do some research. I am working on getting some other parts from Europe now, so I will try to assess if the climate controls are compatible with our AC system and if so, will get part numbers and prices.
I don't think anything would make me happier then being able to select a temperature, instead of constantly fidgeting with the dials...
Old 03-25-2009, 09:28 AM   #2
mrbond
mrbond's Avatar
Hell, even if they're not compatible with our AC system, it doesn't matter to me. I'm prepared to spend up to $1000 on the whole swap.
I know the new Volkswagen Rabbit isn't compatible with the GTI/R32's digital climate control; you'd have to replace the air box and some air hoses and obviously some wiring. When I was thinking of buying a Rabbit, I looked into the price of a total swap. For Volkswagen parts it cost $930 not including labor. These are Toyota parts, so it should be significantly cheaper :D
- A Toyota Yaris
- A whut Yaris?
Old 03-25-2009, 11:22 AM   #3
FEINT
FEINT's Avatar
Drives: Vitz RS 1.5
I don't mind helping if you all want something from Japan.
FEINT is offline   Reply With Quote
Old 03-25-2009, 11:50 AM   #4
Actually, Japan may be a better place to start. Here are the parts that I believe are needed for the conversion (if you could check on pricing/availability for us):
55900-0D210-B0 Control Assy, Air Conditioner
(This is the entire center dash assembly including the "knobs", electronics, and trim)
87106-0D020 Servo Sub Assy, Damper (For Airmix)
87106-0D040 Servo Sub Assy, Damper
87106-0D030 Servo Sub Assy, Damper (For Mode)
(These three replace the manual dampers with ones which are controlled by the above part)
82212-52020 Harness Assy, Air Conditioning, LHD
(I believe that this is the entire cable assembly, including connections to the above and below parts)
88625-47031 Thermistor Cooler (Solar Sensor)
(Sensor mounted under upper dash)
(This part is available in the US, as it is used on many other cars)
88625-22131 Thermistor Assy
(Sensor mounted in front bumper)
88625-47021 Thermistor, Cooler
(Sensor mounted behind AC controls)
88650-0D160
(This is the AC control module, which is mounted to the bottom of the AC assembly)
Old 03-26-2009, 02:20 AM   #5
FEINT
FEINT's Avatar
Drives: Vitz RS 1.5
88650-0D160
Ok. I am calling them next week, so will get back to you.
This is what you want right ??
Old 03-26-2009, 07:19 AM   #6
Correct. The list is that entire module plus all of the stuff that is different on a car with that module as opposed to the manual dials.
Old 03-26-2009, 10:44 AM   #7
vios7
Guy Next Door
vios7's Avatar
Drives: Vios S Sedan
Feint..how much this stuff in yen currency?. can put on sedan?
My account just got hacked last year.
starting back on Oct '08
vios7 is offline   Reply With Quote
Old 03-27-2009, 11:50 AM   #8
FEINT
FEINT's Avatar
Drives: Vitz RS 1.5
I have no idea if it will fit a sedan. I am just helping with getting quotes. Maybe somebody else on here can help you? Sorry.
Digital Gauges, Auto Climate control, Manu-matic shifter computerlove87 Cosmetic Modifications (Exterior/Interior) 21 12-02-2012 11:55 PM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Yaris 09 climate control lights alt_k1ll3r DIY / Maintenance / Service 2 11-11-2008 10:19 PM
Bulbs For Behind The 3 Climate Control Knobs razzorjet2 DIY / Maintenance / Service 2 04-06-2007 10:41 AM
US Speedo and Climate Control swap Master General Yaris / Vitz Discussion 3 06-02-2006 12:56 AM
