The fuel pressure regulator is part of the fuel pump assembly. If you remove the fuel pump/sender gauge from the tank the regulators is pressed into the pump with and o-ring.
#2 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Bayou Blue LB AT Join Date: Oct 2008
That's not good for what I wanted to do but thanks for the information.
aFe Intake | Blitz Supercharger | Megan Header | TRD Exhaust | NST Pulley Set TRD Shocks/Struts | Tanabe NF210 Springs | TRD Sway Bar | Motegi TRAKLITE wheels | Kuhmo Ecsta XS R1 Concepts slotted rotors | Carbotech 1521 brake pads | stainless steel brake lines | Seibon vented carbon fiber hood |
#3 | |
![]() ![]() ![]() ![]() ![]() Drives: 2007 Yaris HB Join Date: Apr 2007
so I can't tell a good calculation from a bad one.Even if I get the scientific concept or whatever, even if I memorize the steps to solve, the simple arithmetic takes me a very long time and the results typically don't mean a thing ![]() I'm kind of in awe of math geeks for whom the numbers make some intuitive sense.Are you one of those freaks, Long? Then maybe you would like to d/l the demo of this--a sophisticated looking fuel injector calculator for windows.http://www.performancetrends.com/Fuel_Injector.htm |
#4 | |
If the regulator is part of the fuel pump assembly, then I can never get any pressure out higher than what the regulator puts out, right? I was hoping that the regulator would be a standalone unit away from the pump that I could replace with an adjustable in-line regulator that could give me higher pressures under certain conditions. Thanks for your thought on this.
#5 | |
I got the info from TIS, as Cammell mentioned. Shoot me a PM with your email address and I'll email the newer fuel section. I think you could pull the internal regulator and put your adjustable regulator in-line. |
| Help with ideas of swapping system out of my other car to my yaris | YarisSedan | In Car Entertainment + Electronics (audio / video / alarm) | 5 | 01-22-2009 01:23 AM |
| 2006 yaris body code. | Adriaan | General Yaris / Vitz Discussion | 3 | 04-26-2006 02:35 PM |
