Old 03-25-2009, 04:33 PM   #1
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
Originally Posted by kurokoma-kun View Post
From the Fuel manual...
"Injection volume: 47 to 58 cm3 (2.9 to 3.5 cu in.) per 15 seconds" (page 17)
To clarify my remarks in another thread: this works out to 212cc/min--using an online calculator to get max hp for this injector volume, I got 130.
Thanks for finding that. I guess I need to learn how to work those calculations for myself.
The fuel pressure regulator is part of the fuel pump assembly. If you remove the fuel pump/sender gauge from the tank the regulators is pressed into the pump with and o-ring.
That's not good for what I wanted to do but thanks for the information.
Old 03-25-2009, 09:02 PM   #2
kurokoma-kun
Drives: 2007 Yaris HB
I wish I could learn how, but I am not good enough at math--as far as things like the max hp I have to rely on a calculator to give me the answer. If the numbers are off I never know why so I can't tell a good calculation from a bad one.
Even if I get the scientific concept or whatever, even if I memorize the steps to solve, the simple arithmetic takes me a very long time and the results typically don't mean a thing I'm kind of in awe of math geeks for whom the numbers make some intuitive sense.
Are you one of those freaks, Long? Then maybe you would like to d/l the demo of this--a sophisticated looking fuel injector calculator for windows.
http://www.performancetrends.com/Fuel_Injector.htm
Help with ideas of swapping system out of my other car to my yaris YarisSedan In Car Entertainment + Electronics (audio / video / alarm) 5 01-22-2009 01:23 AM
2006 yaris body code. Adriaan General Yaris / Vitz Discussion 3 04-26-2006 02:35 PM
