Old 03-26-2009, 02:30 AM   #1
FEINT
FEINT's Avatar
Drives: Vitz RS 1.5
Stuck on my install, advice?
I am stuck on my install.
I got almost everything installed apart from the amps. I haven't wired them. I think I have gotten ahead of myself this time. I have been working on the car for close to 2 weeks and its almost finished, yet so far, its frustrating.
I have 2 amps. 1 for fronts and 1 for sub. When I purchased all the items, I didn't realise there was a bracket for the jack located under the passenger seat. I bought 2 amps with the idea that it was going to go under each front seat.
I dont' really want an amp in the boot.
The amps specs are
4 channel
4 x 80w @ 4OHM
2 x 240w @ 4ohm bridged
and a
1 channel mono
1 x 1500w @ 1 ohm
Speakers : Focal 165 K2P
Sub: Image Dynamics IDMax 12 D2 V3 1000w RMS.
I don't have a garage or tools. Having it cut out would mean I would have to pay a professional to do it.
I am considering:
A) Use the 4 channel ONLY. 2 channels for the front and bridge the rear channels for the sub. I understand that would be under-feeding the sub.
B) Use the MONO only. Run the fronts off the head unit.
C) Pay for somebody to have the bracket CUT out.
Advice Please.
FEINT is offline   Reply With Quote
Old 03-26-2009, 06:21 AM   #2
pariahdecss
Yarisomniac
pariahdecss's Avatar
Drives: 2009 5spd LB
Not a whole lot of options for amp mounting in this car, especially with multi-amp systems. In the boot(trunk), under the seats, or on the back of the rear seats are the most popular. It would seem that for the price you paid for that gear it would be worth it for you to buy a Dremel (or other inexpensive multi/cutting tool) and tediously cut it out of there yourself - DIY and save some cash in the long run. Dremels or a similar tool are invaluable for system installs. I intentionally bought a single amp with a really small footprint, and stuck it in the boot, because I knew mounting it would be difficult in this car.
pariahdecss is offline   Reply With Quote
Old 03-26-2009, 06:31 AM   #3
goku87
goku87's Avatar
Drives: Black HB
If you absolutely don't want an amp in your trunk, then:
http://www.lowes.com/lowes/lkn?actio...-01&lpage=none
lay down some heavy duty plastic and watch for sparks that may cause FIRE
goku87 is offline   Reply With Quote
Old 03-26-2009, 07:28 AM   #4
The amps specs are
4 channel
4 x 80w @ 4OHM
and a
1 channel mono
1 x 1500w @ 1 ohm
I am considering:
Advice Please.
What about mounting it to the bottom of the seat? There is plenty of clearance between the seat bottom and the jack mount. You might have to get a little creative with the brackets, but there are quite a few places you could bolt L-brackets to.
Old 03-26-2009, 08:25 AM   #5
WolfWings
WolfWings's Avatar
Why not mount things under the rear seat instead of the front seat? Or do you have the funky trash-compactor tilt/slide/fold-flat split rear seat? :-)
Old 03-26-2009, 10:45 AM   #6
FEINT
FEINT's Avatar
Drives: Vitz RS 1.5
Thanks for the replies. You all have some interesting ideas that I might try.
Rear seats fold down but the bottom section doesn't move. Its fixed. I will have to see if an amp will fit under there. It isn't much space underneath. The amps are also quite large.
I did want to do that. However, we have a pull out tray for stuff to be stored under the seat. I am going to try to remove that tray and replace the amp there. I will have a look, thanks!!!
That was the last thing I wanted to do considering the car isn't even 2 weeks old. I really didn't want to tear the thing apart.
I didn't think of these things when I first bought the car. I thought small cars would be easier to work on, how wrong was I!!! It was totally the opposite. Everything is so compact and hard to reach! But getting there slowly. If I knew it was that difficult, I would have gone with single amp setup.
Thanks for the comments and input EVERYONE. It really helps. Gives me a few more ideas to have a look at tomorrow.
Old 03-28-2009, 11:40 AM   #7
FEINT
FEINT's Avatar
Drives: Vitz RS 1.5
Had a look under the rear seats. No way the amp would fit.
I had a look under the passenger seat and without removing that bracket, amp is a little too large to fit.
Size of the amp : HxWxD(mm) 64 x 400 x 222mm
Any more ideas before I consider the worse case scenario which is CUTTING out the brackets?
Old 03-28-2009, 11:43 AM   #8
How about just bending the tabs down on the bracket? That would gain about 5 cm.
Old 03-28-2009, 11:44 PM   #9
FEINT
FEINT's Avatar
Drives: Vitz RS 1.5
Originally Posted by m911gt
has anyone checked to see how the bracket is mounted to the floor of the car? I don't see why Toyota would weld a jack bracket in place, it may just be bolted in.
Thinking of doing that before cutting.
I checked that, its not bolted in. Its welded in. But its not hard hard metal. So going to try bending the brackets first then, cutting if that doesn't work.
Originally Posted by talnlnky
There is no such thing as "under feeding" when talking about amps & speakers.
That sub would be fine with 250ish watts... but... you most likely would want a bit more umph.
Personally... I'd bridge that 4 channel to run those Focal's and remove that mounting bracket even if it meant having to pay somebody $50 to cut it off just so I could run that 1500 to the IDMAX
Thanks. That would be ideal solution having the 4 channel bridged on the Focals and Mono on the iDMax.
Originally Posted by Yarisugi
Does the amp fit in the front pull tray? I think that would be the best place to put it.
Doesn't fit, its too large. Thanks for the idea though.
Thanks everybody. Will try bending, if that doesn't work. Bring on the angle grinder.!! My 2 week old vitz is going to get the AXE! :)
Old 03-28-2009, 12:13 PM   #10
m911gt
Carless in Chicago
m911gt's Avatar
Drives: 08 Blk LB
Wanted: Forced Induction
Old 03-28-2009, 07:15 PM   #11
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
Old 03-28-2009, 07:57 PM   #12
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Old 03-29-2009, 12:01 AM   #13
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
FEINT... what part of Japan are you in? I lived in Osaka back in 07.
Old 03-29-2009, 01:29 AM   #14
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Oh damn? Really? I used to live in Yokuska and Misawa! Small world!
― Thomas Paine
Old 03-29-2009, 03:23 AM   #15
IsLNdbOi
IsLNdbOi's Avatar
Just bend it. On my '07 LB, I put a powered sub. under the driver seat. Had to bend that thing to get the sub. under the seat.
Old 03-29-2009, 08:23 AM   #16
FEINT
FEINT's Avatar
Drives: Vitz RS 1.5
Thank you. I will be doing that tomorrow.
I am in Nagoya. :) Looks like a few of you have been or lived in Japan! :)
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 01:15 AM
Quick advice needed on unfinished amp install GreenSpeed In Car Entertainment + Electronics (audio / video / alarm) 15 01-15-2009 11:03 PM
srs / airbag light after head unit install? KwonSau In Car Entertainment + Electronics (audio / video / alarm) 7 12-24-2008 02:04 AM
where can i install these power locks? songa New England 1 12-04-2008 12:41 PM
