Old 03-26-2009, 05:46 PM   #1
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Originally Posted by harveyjai View Post
I got TRD springs ad shocks, Ku36 tires, and Ultraracing rear sway bar.
It does do well, is just that i m thinking whether the bushing will improve even more.
Btw, is it worth it to replace my TRD spring into TANABE DF210?? would that
give me lower ride height and stiffer setting?
No you stay with the TRD's. The Tanabe will drop yor car a little more than the TRD's but they are not stiffer.
The TRD shocks and and springs were designed to work together.
You are on the right track with your set up...
unfortunately there are no bushings for the Yaris yet.
You can look into the front camber bolts. Garm sells those or you can probably got them locally also. It's a cheap mod that will help you to dial a little bit of negative camber.
Other than what you have there is not much more to do... other than go to a full coilover set up...
There are a bunch of braces available but you alrady got the rear sway bar and that is the most important...
I say you go out and drive and enjoy your car... it should drive pretty well by now...
Old 03-28-2009, 06:34 PM   #2
harveyjai
Touge Driver
harveyjai's Avatar
Drives: Yaris YRX
Originally Posted by CASTREX View Post
No you stay with the TRD's........
i did enjoy my car..thanks for advice buddies!
http://www.youtube.com/watch?v=F3iZuZ6VrOQ
harveyjai is offline   Reply With Quote
Get your post counts here! *read 1st post for rules* Astroman Off-topic / Other Cars / Everything else Discussions 3414 11-04-2012 09:03 AM
Do any other Toyota front seats have same bolt pattern as Yaris? ScottFern DIY / Maintenance / Service 18 07-02-2007 11:44 AM
Dont forget the camber bolt. nurburgring Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 05-23-2007 04:39 AM
