Old 03-31-2009, 08:44 PM   #1
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
^ha...oh you are serious?
Old 04-14-2009, 01:09 PM   #2
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
whoa... a turbo hyabusa engine at 350hp in a yari.... yikes....
Old 04-14-2009, 05:05 PM   #3
Russelt3hPirate
l33t3st Asshole
Russelt3hPirate's Avatar
Drives: MY07 Yaris Liftback
compress compressed air. do it.
and post up all the money you wasted to get a car that's slower than a stock WRX.
while you're at it you could run some turbos in series. get 150 psi!! do it would make made powar.
Russelt3hPirate is offline   Reply With Quote
Old 04-20-2009, 10:18 AM   #4
Russelt3hPirate
l33t3st Asshole
already been done.
using a custom Turbo Kit and a blitz charger.
Old 04-20-2009, 11:10 PM   #5
changchewsoon
Drives: Vios Turbo
Send a message via MSN to changchewsoon Send a message via Yahoo to changchewsoon
That's the BrashBoy dual charged Yaris.
http://www.brashboy.net/english/dualyaris.html
454 whp, 1.7 bar boost, pump gas, water/meth.
501 whp, 2.2 bar boost, pump gas + avgas, no water/meth.
www.viosturbo.com - World's first 500 WHP 1NZ-FE
changchewsoon is offline   Reply With Quote
Old 04-21-2009, 02:14 PM   #6
sasquatch
Drives: 04.:R32, 87 Scirocco, 07 yaris
that twin charged yaris is awesome.
until i saw that i was going to say that it is totally possible, possibly using mega squirt or another stand alone system to run the fuel/spark and avoid the tricky stock yaris ECU.
VW currently makes a production 1.4 twin charged engine making 170hp.
also some guy in denmark(i think) made a custom supercharged/turboed 1.8t GTI making 500hp. he actually used 3 ECU's to run the car: 1 for the turbo, 1 for the supercharger, (running 8 injectors) and 1 for the rest of the car. i could only imagine what a no lag 500hp would feel like
sasquatch is offline   Reply With Quote
Old 04-23-2009, 05:52 PM   #7
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
Originally Posted by Russelt3hPirate View Post
already been done.
holy shit
Old 04-24-2009, 01:02 PM   #8
whooppee777
So i emailed brash boys the responded very quickly. heres my inquiry followed by their response.
"I noticied you guys make a dual charged kit for the yaris. I have
Yaris with the Blitz Supercharger and naturally I want more power. I
was Curious if you could inform me as to what size turbo you use in
your kit, how much boost does the turbo makes, how much additional
boost can the Blitz supercharger handle, and I was curious if it would
be possible to get a copy of the Installation manual for the dual
charged kit. I would even pay for the manual, just so i could get
some sort of idea of how to route the piping, even though the chasis
codes are not the same it would help a lot.
Thanks"
"Hello.
Our dual charger does not sale by kit model, sorry.
Engine;
Forged connecting rods
Forged low compression pistons
Forged valve and valve spring
Power FC
Boost 1.0k
270HP
If install the sleeve in the block, will go up boost 1.2k, over 320HP."
So now the search begins for sourcing and pricing Forged Connecting Rods, Forged Low Compression Pistons, Forged Valves & Valve Springs, Standalone Engine Management, a place to sleeve the block, turbo exhaust manifold, turbo, and a way to fortify the crank just to be safe, fortified axels. plus anything else i forgot
Old 04-24-2009, 01:59 PM   #9
whooppee777
The Quest Begins
Used 1NZ-FE Engine
Junk Yard
$ Cheap As Possible
Turbo Manifold
http://www.365motorwerks.com/turbomanifolds.aspx
$375
Turbo
Sleeved Block
Fortified Axles
http://www.yarisworld.com/forums/sho...highlight=axle
Fortified Crank
Standalone ECU
The other necessities will be added once the above is sourced
Old 04-24-2009, 02:01 PM   #10
Tamago
Tamago's Avatar
Drives: UZJ100
you'll make more power with just a turbo.. /thread
Old 04-24-2009, 02:27 PM   #11
whooppee777
anyone can just go turbo. (or can they i.e. tuning issues)
u seem to be missing the point.
its about being the only guy in the country with a twin charged yaris.
let alone a twin charged anything, less than a handful of people can say they have that.
Old 04-24-2009, 03:29 PM   #12
Tamago
Tamago's Avatar
Drives: UZJ100
why not be the only yaris that has only 3 wheels? cut a hole in your trunk and put one wheel in the back, now THAT will turn heads
Old 04-24-2009, 03:32 PM   #13
Russelt3hPirate
l33t3st Asshole
don't forget stronger trans and an LSD.
if you're the only guy in the country with it be prepared to build more than 1 engine, more like 7 or 8 before you get the tuning right.
if you're looking to do something "on the cheap" then the last thing you want to be is the "first"
the first person is the person who spends the most $$, didn't you take economics and marketing?
Old 04-24-2009, 04:17 PM   #14
whooppee777
turn head yes. cool/feasable not really
the trans im not too worried about. if it blows i'll replace it with something stronger. the lsd is an upgrade i do intend to do.
no not worried about the money this is a project i see stretching across 2 years or more. i kinda see cali yaris as the real first to go for power in the
300hp area. i'll b sure to keep him on speed dial and learn from his mistakes, if he makes any.
i took intro to economics. but that was about 2 years ago. i must have slept in on the day they covered twin charging an econo box.
so does anyone have anything to add as far as my needed parts go?
Old 04-24-2009, 08:20 PM   #15
Tamago
Tamago's Avatar
Drives: UZJ100
i want to twin charge my yaris
turns head yes, cool/feasable, NOT REALLY
Old 04-25-2009, 02:27 AM   #16
whooppee777
is there a button on here i can click that prevents the pessimists from posting on the forums?
Old 04-25-2009, 02:39 AM   #17
Tamago
Tamago's Avatar
Drives: UZJ100
yes, here it is
http://www.yarisworld.com/forums/log...124c8e83b90456
Old 04-24-2009, 04:22 PM   #18
Russelt3hPirate
l33t3st Asshole
besides little stuff?
have you decided on compression ratio?
slap on a GT30R .76 AR, you don't need low end, you need top end.
new cams.
you're going to have to find the best tuner in the world to get this to run at all.
probably some 600cc injectors too, external fuel pump wouldn't be a bad idea.
2 more built 1nzFE's for the first time you over boost the turbo and can't provide enough fuel (most likely the 3rd or 4th dyno pull).
how much do you forsee this costing you? you pretend $$ isn't a factor, but once you figure out how much you're potentially going to dump into this car you may choose another route.
my guess is around $30k to get it to the point of reliability and more than 250whp use able and safe.
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 01:15 AM
So... twin DIN install. (NOT Double DIN) Is it possible? WolfWings In Car Entertainment + Electronics (audio / video / alarm) 15 04-01-2009 08:49 AM
Twin engine Yaris. ddongbap Off-topic / Other Cars / Everything else Discussions 18 12-15-2008 10:54 PM
Twin Charge!!! (the best of both worlds) DollaZo Forced Induction Forum 51 11-15-2008 01:07 PM
JDM STABILIZER CHARGING SYSTEM ketel0ne Performance Modifications 15 09-13-2006 08:56 PM
