Old 03-27-2009, 01:20 AM   #1
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
Ok, I just spent a half hour on the phone with dyno guy. He does not recommend that I start with larger injectors or more powerful fuel pump. He recommends a boost-sensitive adjustable fuel pressure regulator.
Thanks to CTScott, I found the OEM fuel pressure regulator. It is not in a place that is easily replaced by an aftermarket unit. Since the fuel system's pressure is now maxed out at the 44.1 to 49.7 psi put out by the OEM regulator, using another regulator after this unit to get higher pressure is impossible.
Dyno guy now admits that replacement of the fuel pump (like Garm's turbo install) or replacement of the stock injectors is probably in order if the goal is to get more fuel to the engine during boost.
Calculating the proper injectors size, using the many online injector calculators, is a little bit daunting but I'll use them all until I can understand the concept and get consistent results.
I'd rather understand the science behind the proper selection of injectors rather than just shotgunning any device in and hoping that they do the job adequately.
Old 03-27-2009, 03:38 AM   #2
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
If that is truly the problem, you could try a boost-a-pump. You need a scan gauge or tool that can tell you injector duty cycle to know for sure if you need anything.
You guys will not be able to solve this by just swapping out parts. You will solve one problem and create 5 more with bigger injectors.
Old 03-27-2009, 09:42 AM   #3
LtNoogie
LtNoogie's Avatar
What is a boost-a-pump? Can you post a link to a comparable product online? I have not seen injector duty cycle as available for display on the ScanGauge. I am guessing that some instrumentation would have to be connected to the injector wires to measure duty cycle? This intrument would have to be sturdy enough to measure during WOT?
Old 03-27-2009, 11:27 PM   #4
TOUGEghost
Mr. Clean
TOUGEghost's Avatar
Drives: 2009 Yaris S 3-Door
Here's the link:
http://store.summitracing.com/partde...5&autoview=sku
It increases voltage to the fuel pump as boost increases. Seems like it could be a good solution for moderate boost levels.
Old 03-27-2009, 11:46 PM   #5
LtNoogie
LtNoogie's Avatar
Originally Posted by TOUGEghost View Post
Here's the link:
Thanks, I had seen that earlier. My thought is that a properly working fuel pressure regulator will hold the current pressure unless it fails. My water pressure regulator at the inlet to my home maintains a constant 80psi across a wide band of street pressure.
Any mechanical engineers out there?
Old 03-28-2009, 12:48 AM   #6
dallas
Drives: Yaris Hatch /Landrover D2
Ive seen the Boost-a-pump used on a buddys Mustang and it works well, if you need to squeeze a bit more out of the fuel pump. If Richard Holdners Intake /exhaust combo made more hp than the supercharger it must be using more fuel to acheive this. I don't think it's the fuel delivery, but maybe the management of the delivery thats causing a lean condition. I wish you pioneers luck to figure this out.
dallas is offline   Reply With Quote
AFR running extra rich at WOT? eTiMaGo Performance Modifications 15 03-10-2007 11:10 AM
