Old 03-28-2009, 01:01 AM   #1
well the blocks are completely different (NZ vs ZZ), so swapping them would not be possible, but the intake manifold, maybe, who knows, might get lucky, if you can get your hands on one, give it a try!
Old 03-28-2009, 01:20 AM   #2
dallas
Drives: Yaris Hatch /Landrover D2
Thanks, that's what I thought but was not certain, in my old school "daze" of building Datsuns they had 1.6, 1.8 and 2.0 and there was a lot of interchagability between blocks heads, cranks, and pistons etc to yield higher compression ratios etc. Do you know if the cylinder heads are the same?
Im tempted to get the intake to compare the flange if it's the same, I will fill both with measured amounts of water to see if one has more internal volume, and may perform better. Why just change the throttle body if a manifold with more volume may work! We could call it the low cost "Holdner"
dallas is offline   Reply With Quote
Old 03-28-2009, 01:35 AM   #3
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
LOL
I would try this but my wallet does not accommodate it this month or next month.
http://cgi.ebay.com/ebaymotors/TOYOT...ayphotohosting
intake manifold photo richardholdener Performance Modifications 94 08-04-2009 01:25 PM
Yaris Intake Manifold richardholdener Performance Modifications 201 05-18-2009 11:58 AM
Intake Manifold Gasket? Nexus1155 DIY / Maintenance / Service 6 11-18-2008 08:03 PM
Official Richard Holdener *MID-RANGE* Intake Manifold List WolfWings Performance Modifications 59 11-13-2008 11:26 PM
