Old 03-28-2009, 12:40 PM   #1
kustom play
pink wheels are cool
kustom play's Avatar
Drives: 07 liftback
So i installed my steering wheel but have a few Qs
so heres the install:
so install went rather smooth but.....
i didnt realize that the grant wheels are 5 bolt and all the hub adapters are 6
bolt :doah:
so i ordered a grant adapter ring and a new solid black horn button so problem solved
next question is how did you peeps who swapped your wheels turn off the air bag light
is there a fuse you can pull?
also which wire is the horn wire? i need to tap it and run it up into the hub
thanks in advance!
Old 03-28-2009, 12:59 PM   #2
kou
Drives: 08 lb
? where did you get the parts from.
Old 03-28-2009, 01:07 PM   #3
kustom play
Drives: 07 liftback
i picked up a generic toyota hub from ebay (8 bucks shipped!)
the good: works perfect looks good
then bad: you lose you auto turn off for you blinkers
i had to trim the plastic boot that came with the hub a little to make it nice and flush (really easy with an a-acto knife)
i found the grant wheel online
i found the 5 to 6 grant adapter and the horn button from summit racing
i have a momo hub on my MR2 and its the same way with the turn signal
over time i might swap the hub to something that allows me to keep the spiral cable so i can use the auto turn off ( i remember Garm saying one of the hubs will allow for this)
but its not bad for now and it works great
Old 03-28-2009, 02:40 PM   #4
running a wire up through there that will then twist every time you turn the wheel is dangerous. I want to make sure anyone considering this mod understands the risks of using aftermarket hubs that don't use the clock mechanism.
Works Bell is the hub to get if you want a safe installation + turn signal cancellation.
With that said - Looks good!
Old 03-28-2009, 03:03 PM   #5
kustom play
Drives: 07 liftback
the way to work around that is to tap the horn wire and run it through the hub leaving slack in the hub itself
it allows the wheel to turn without putting stress on the line (since you have extra slack in the hub)
thats how i have it set up on the MR2
but for the daily driver i might switch out hubs so i can use my spiral cable
ive been looking at the Works Bell set up but cant find one for the yaris
Old 03-28-2009, 05:34 PM   #6
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
AHHHH wheres my sun glasses , that is bright,
not my color at all , but you love it so that is all that counts.
well done.
Old 03-28-2009, 05:52 PM   #7
Norkotik
Drives: Yaris
that looks tight
Norkotik is offline   Reply With Quote
Old 03-28-2009, 07:09 PM   #8
kustom play
Drives: 07 liftback
its not really that bright in real life
for some reason photos make it look super bright
even when i bought it, it looked a lot brighter then what came
Old 03-28-2009, 07:18 PM   #9
YAR1S
YAR1S's Avatar
haha love the color-matching :]
-Jen <3
Old 03-28-2009, 08:33 PM   #10
blacksandiegovitz
Your mom goes to college
blacksandiegovitz's Avatar
Drives: 08 Vitz
^^ 2nd that , just throw down on the works bell hub , worth it
I really do like the pink steering wheel/ rims
Old 03-28-2009, 10:46 PM   #11
kustom play
Drives: 07 liftback
my pink shift boot just came in today too lol
i'll grab some pics tomorrow
Old 03-28-2009, 11:12 PM   #12
for the airbag light apparently you can connect a resistor across the original wires, though I am not sure of the details, think 03Z33 mentioned it a long time ago... Mine's on all the time and I just ignore it, I might just open up the cluster and block the light with a piece of black tape eventually
Oh and I gotta say, that pink steering wheel is HOT!
Old 03-28-2009, 11:19 PM   #13
kustom play
Drives: 07 liftback
haha thanks
it started off with pink wheels and then i or other people find these pink things and there like "ohh man you need to get this too"
its been fun though, nobody else has pink!
my g/f keeps trying to make me get these:
Old 03-28-2009, 11:47 PM   #14
you gotta stick with the theme now, for better or worse
Old 03-29-2009, 12:03 AM   #15
kustom play
Drives: 07 liftback
haha
i dont know if im read to take that next step...
Old 03-29-2009, 01:33 PM   #16
kustom play
Drives: 07 liftback
Heres the pink boot, i just put it on there for now, i have to secure the base in
ive been busy working on the MR2
just picked up this setup here:
and for fun this is the g/f's TC its a 3.0 release series with a ton of crap done to it
its been a busy weekend at our house and next weekend were heading to cali (San Diego) to visit a friend so if you see the yaris wave!
Old 03-29-2009, 01:41 PM   #17
nice collection
whatever you do, never EVER put a purple shift knob on top of that boot
Old 03-29-2009, 01:47 PM   #18
kustom play
Drives: 07 liftback
hahaha
there goes my plan for my cool purple neon shift knob :(
Works bell/Nardi quick release steering wheel setup blacksandiegovitz Cosmetic Modifications (Exterior/Interior) 35 09-02-2009 05:52 PM
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
Steering Wheel Issue. Twistoffate0817 General Yaris / Vitz Discussion 8 01-31-2009 07:38 PM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
steering wheel setup aucorium Cosmetic Modifications (Exterior/Interior) 0 07-24-2007 01:05 AM
