Old 03-29-2009, 11:24 PM   #1
njiteb
Mario Mushrooms & Totoro!
Drives: Absolutely Red Yaris LB 2007
sorry to bring up an old topic, but i can't seem to get the cover off of my hatch light or the map lights..only got the dome one done for now.. anyone can help?
njiteb is offline   Reply With Quote
Old 03-30-2009, 12:20 AM   #2
Meteorite_Marty
For both, you will need a very small flat head screw driver.
The map light covers can be removed by placing the screw driver in the center gap, in between the pair. Then press towards the outside, away from the centre. Each of the covers are on 2 small pop-off hinges, located at each corner nearest the center. It might help if you move the screw driver towards one of the hinges, while keeping it in the center gap, then apply the pressure towards the outside, as mentioned.
The trunk light is held on by a plastic clip, under the grey plastic of the interior. Itcan be popped off by inserting the screw driver on the front edge of the light housing and lifting upward and out.
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
How do you replace the factory fog light bulb DjT DIY / Maintenance / Service 6 10-25-2008 07:24 AM
GROUP BUY - JDM (RS) Vitz LED Tail Lamp ... riceboy Items for Sale by private party 453 07-14-2007 08:30 AM
Cheap LEDs Interior and Exterior jamal1984 Cosmetic Modifications (Exterior/Interior) 10 04-11-2007 11:08 AM
Yaris S Replace Fog Light Bulbs jamal1984 DIY / Maintenance / Service 1 01-13-2007 08:16 PM
