Old 10-03-2006, 06:34 AM   #1
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
Send a message via AIM to vodkalush
Originally Posted by bigsky2
Do you mean the RCA preout from our head unit or from the amp?
Depending on your amplifier, it could allow you to output low/hi sound levels to another amp.
If it's from your head unit, and you have more than 2 pre outs, then definitely yes.
I'm guessing it's the preout from the amp, which I would need more info to give you a better answer.
E.g.
Which preouts from your headunit did you connect to your installed amp?
Does the preout on your installed amp have a HI/LO pass filter?
I'm using the stock hu. so the amp does take hi/lo - its a pioneer gm-6200f (http://www.pioneerelectronics.com/pn...568903,00.html)
Docotrs say all the drikning has mesesd up my seplilng and radieng
will work for parts
vodkalush is offline   Reply With Quote
Hatch/Liftback Owners with AMPs - Where did you connect the ground? bigsky2 In Car Entertainment + Electronics (audio / video / alarm) 10 09-28-2006 02:21 PM
Amps, Subs, Bandpass... Yar In Car Entertainment + Electronics (audio / video / alarm) 26 09-08-2006 01:20 AM
